SHIMANO 10 SPEED 11-42 vs SUNRACE 11-42- Mtbr.com
Results 1 to 27 of 27
    Aug 2017
    Which is lighter when it comes to weight, and durability? shimano 10 speed 11-42 or the sunrace 11-42 10 speed?
    RAKC Industries
    Jan 2017
    Shimanos cassette is bottom of the barrel, the better of the sunrace one will be lighter.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    Oct 2013
    well...(sounds like) there is a Shimano 10 speed 11-42 introduced with the new Deore M6000 series.
    Been using both Shimano XT converted cassettes (to 11-42) and Sunrace 11-42 and the Sunrace shifts a bit better around the 16t cog, Shimano converted lasts longer.
    I would go for the new Deore CS-HG500-10 if I was to buy today, if it's anything like the HG50 Deore it's a solid cassette that will last longer and give you the Shimano smooth shifting.
    Yeti SB100
    Transition Smuggler
    Reputation: uzurpator's Avatar
    Dec 2005
    There is a CS-HG500 11-42 cassette - 10 speed.
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by mevnet View Post
    well...there is no Shimano 10 speed 11-42 unless you're talking about a converted Shimano cassette with a kit from OneUp, Wolftooth, etc.
    Have both and the Sunrace shifts a bit better around the 16t cog, shimano converted might last longer.
    Well... yes there is. Shimano HG50 10-Speed 11-42t Cassette
    Quote Originally Posted by hamsterboy View Post
    It's not bottom of the barrel, it's a Deore level cassette. I've used at least 4 wide 10 Spd Sunrace cassettes. They're OK, they do the job but in my experience they wear really fast and don't shift great with XT/SLX derailleurs (The Goatlink helps). It's tolerable, but I'm guessing the Shimano unit will shift better and last longer. I just bought one but haven't installed it or ridden it yet.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Oct 2013
    Quote Originally Posted by uzurpator View Post
    What do I know? Thx for the correction lol
    Yeti SB100
    Transition Smuggler
    RAKC Industries
    Jan 2017
    Its a brand new addition to shimano. New release shimano 10s RDs (at least deore and slx) do fine with it, no mods.
    Jun 2015
    I've not been able to locate a weight spec on the CS-HG500 11-42 10 speed cassette. Anyone else find it?
    Jan
    Jan is offline
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    I have the 11 seed version of the sunrace on my fatbike. I folded the big cog with the original design, but since they replaced it with the newer design, it's held up well. I'm 230 lbs mashing 28/42 gearing with fatbike traction, so its been tested to handle some decent torque. I wouldn't hesitate to buy the sunrace again.
    Nov 2016
    I think we can all agree that Shimano stepping up their 10 speed range with the M6000 RD will mean a lot to the continued existence of wide range 10 speed cassettes, though, which is something that makes me happy as I am just now moving to 1x10.
    I know I'm 2-3 years behind, but it seems to fit my needs and is cheaper than 1x11. ;-)
    Looks like the carrier for the largest gears is big enough not to gouge an aluminum hub.
    May 2016
    Yes, I bought RD-M6000 GS Shadow+ and it work's great with 11-42 SunRace MS3.
    Reputation: Flash's Avatar
    I just installed the 11-42 HG500. Replaced the MX3 Sunrace. The Shimano shifts great minus 1 issue. It is very slow to drop off the 15. The Sunrace did just fine. New cable and housing. New chain. XT derailleur. [email protected] with it for quite a while. Put the Sunrace back on. Drops just fine. I'm going to try it on my hardtail that has 11-42 Sunrace. If I have the same issue it's going back. All shifts are great except having to double tap down 2 cogs to get it to drop off the 15.
    Sent from my SM-N950U using Tapatalk
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Flash View Post
    That sounds like a setup issue. It's a Shimano product with a Shimano product, and the parts are new. Should be flawless.
    Check your derailleur hanger alignment. Check your B-screw. etc. If you can't figure it out have a mechanic look at it.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Hanger is straight. B screw is perfect. It's only doing it with this cassette. I've set up dozens of these but this is the first time for this particular cassette. I'll look at it again today with a clear head.
    Quote Originally Posted by *OneSpeed* View Post
    Wanna ride bikes?
    Oct 2013
    Maybe try changing out the shift cable in case it's kinked somehow?
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    I think that will be my next step. I took it out to a nice flow Trail today and I had one wheel with the sunrace on it and it did fine. Then I did another lap swapped out the wheel with the Shimano cassette. It did better than it did on a stand but still at times there was a bit of a burp when dropping down off that 15.
    Wanna ride bikes?
    Oct 2013
    Not that I think this is the cause/fix, but I noticed an improvement in shifting when I added a Wolftooth Goatlink.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    I just ordered one. Hope that helps. I could leave the Sunrace on but it's getting a bit worn. I've been trying this on my Epic. Plan on mounting to my Fuse just for fun. I take it personally when I can't get perfect shifting and actually like the challenge. Most every build I've done works very well from day one so I guess have time for a challenge.
    Reputation: crankpuller's Avatar
    I don't know about weight but the shimano definitely shifts better. I have both-
    Sent from my Pixel 2 XL using Tapatalk
    The Shimano is about 45 grams more than the Sunrace.
    Quote Originally Posted by crankpuller View Post
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Hmmmm...my 11-40 MX3 shifts as well as my old 11-36 XT. I honestly can't tell a difference in performance and really prefer Sunrace's steps between gears vs Shimano's 11-42. Been using it for close to 1K miles of singletrack and still going strong.
    :nono: :thumbsup:
    DFMBA.org
    Reputation: MTBeing's Avatar
    Reviving an old thread...
    Can anyone chime in on the Goatlink with either setup? From what I've read, it's almost a must with the Sunrace. I'm happy to spend the $20 if it helps with the Shimano cassette?
    Also, how is the wear with the Shimano cassette vs. the Sunrace. 45 grams is nothing to me if I could get more longevity off from the Shimano.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Nov 2016
    Does anyone know what are the differences between the two cassettes below?
    https://www.chainreactioncycles.com/.../rp-prod162566
    https://www.amazon.com/SHIMANO-Tiagr.../dp/B072TS85WS
    Jan
    Jan is offline
    It's the same cassette.
    Nov 2016
    According to manufacturer response "Tiagra is the road version of the deore on mountain bikes".
    Is this info correct?
  1. Sunrace CSM99 9-Speed 11-36T Cassette.
    By Ronnie in forum 29er Components
    Last Post: 10-07-2016, 11:40 PM
  2. Sunrace 11-34t vs. Shimano 13-34t 7 speed cassette
    By duckie.nv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2016, 12:01 AM
  3. sunrace 11-42 10 speed vs shimano/sram 11 speed
    By goodmojo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2016, 05:59 PM
  4. Sunrace 7 speed 11-34 cassette
    By TLD80 in forum Families and Riding with Kids
    Last Post: 06-06-2015, 12:32 PM
  5. I'm looking for opinions on the Sunrace CSM99 9-Speed 11-36T Cassette.
    By Ronnie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-22-2014, 05:07 PM
Members who have read this thread: 38
