Results 1 to 11 of 11
    Jun 2013
    Replacement bearings for BSA30 bottom bracket?
    The Race Face BSA30 bb I've been using has creaked since almost from day one under hard pedaling. I'm tired of the creaking is constant and ran across a video on youtube showing that the bearings can be replaced. I looked on RWC but don't know if it's as easy as buying just the bearings or if I need to buy a 'kit' that comes with wave washers, spacers, etc ? Plus is it recommended to go with the ceramic hybrid bearings for riding in dry, dusty conditions in the summer and wet, muddy in the fall/winter?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Something with angular contact bearings.
    They've been great for me in both BB30 and PF30 setups. The bearings are the same, just housed in aluminum bodies/carriers of different shapes.
    http://enduroforkseals.com/id343.html
    Sent from my XT1585 using Tapatalk
    Death from Below.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    What about Threaded to 30mm Angular Contact BB - Black ?
    Edited for right spindle size
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Formerly of Kent
    He needs a 30mm spindle...
    Death from Below.
    Jun 2013
    Quote Originally Posted by Le Duke View Post
    Thank you my bad I'm tired lol
    SRAM XX1
    Jun 2013
    Thanks for all the info guys. Sucks that the Wheels Mftg bb is out of stock right now, or should I step up to the ceramic hybrid bearings considering the conditions I ride in (dry and dusty in summer, wet and muddy in winter)?
    Jun 2013
    Quote Originally Posted by matadorCE View Post
    I've been running a Chris King ceramic PF bottom bracket on my Stump Jumper HT for the last year.
    It's so smooth I wouldn't run anything else.
    I'm in the process of building a Carbon 29 HT and it has a BB 30 bottom bracket so I'm going to run the Wheels Manufacturing Ceramic "Zero" Bearings.
    YMMV
    SRAM XX1
    Reputation: RSAmerica's Avatar
    I went through the same thing with a RF BSA30 BB. The bearing only lasted a month. I replace the bearings with Enduro then SRAM ceramic bearings. They both did not last.
    Now I have a Rotor BSA30 BB with steel Enduro bearings and not problem after a years. I found it on eBay cheap.
    I thing the RF BSA30 is just junk.
    Jun 2013
    I managed to replace the bearings on the RF bb with some zero ceramic bearings but now my bb creaks like crazy. I already replaced my suspension linkages to I'm coming to the conclusion it's the bb itself.
    There's Rotor BSA30 on eBay now.
    Jun 2013
    Cool, I'm going to give that a try because I can't stand the creaking
  1. Can I remove the inner sleeve on the RF BSA30 bottom bracket?
    By KRob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-10-2015, 02:20 PM
  2. Replies: 10
    Last Post: 08-07-2015, 07:23 AM
  3. Sram GXP bottom bracket bearings
    By fuzzz in forum SRAM
    Last Post: 07-20-2015, 12:22 PM
  4. Hope bottom bracket bearings
    By elongate in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2015, 12:07 PM
  5. Need new Bottom Bracket / bearings..am lost
    By AXOP in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2011, 06:34 AM
Members who have read this thread: 19
