    NWS
    NWS is offline
    Jun 2010
    Replace 8-speed cassette with 10-speed?
    Is the freehub width the same?
    My wife doesn't want a new bike but I'd like to upgrade her to 1x10 if possible. Or 1x9, anything to get rid of that front derailleur.
    I realize I'll need to swap the shifter, derailleur, and chain as well.
    Reputation: bvibert's Avatar
    Mar 2006
    Quote Originally Posted by NWS View Post
    Yes, 8, 9, and 10 speed all work on the same freehub.
    Reputation: watts888's Avatar
    Oct 2012
    yes. it'll work fine. Also grab new cables/housings. Only need the one for the rear derailure, so it shouldn't cost more than $5-$10.
    What cassette is she currently running? The gear spacing on 10 is nice, but not sure it's always necessary. Schimano's 11-32T cassette has good spacing between gears, and it works like a tank. Only downside is weight, but that's because all the good parts ae for 10-speed anymore.
    "a hundred travel books isn't worth one real trip"
    NWS
    NWS is offline
    Jun 2010
    Thanks, I'm doing this for sure then. With a new cable too.
    I'm not sure exactly but her current cassette looks like about 15t-25t or something like that. It's a ridiculously small range.
    Right after i posted this i remembered I have a lightly used 9sp 11-34 sitting around, I'll probably use that.
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. 11 Speed cassette, chain, rear mech and shifters with 10 speed cranks/rings.
    By devans in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2015, 01:47 PM
  3. 9 speed derailleur on a 8 speed cassette with an 8 speed shifter?
    By Nicdog911 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2015, 08:29 AM
  4. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  5. Confused about 7 speed Shimano Megadrive cassette, possible to convert to 8 speed?
    By Nick_M2R in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2014, 02:56 PM
