Results 1 to 19 of 19
    Jul 2015
    Removing SLX crankset for 1x conversion
    Hey all
    In process of removing my SLX crank arm so that I can unbolt the 2x chain rings and attach my raceface 30t narrow wide . Do I need the tool to remove the black crank arm cap on the non drive train side or is there an easier way to access the hex bolt?
    Pairing with a praxis 11-40 on the rear .
    Jul 2015
    Reputation: giantdefy's Avatar
    Jun 2010
    Loosen the 2 hex pinch bolts. Stick a long nose pliers in the center plastic cap , spread open the pliers so it catches inside the center cap and turn clockwise. Once its twisted off, just pull the non drive side crank arm and take a rubber pallet and tap the crank out.
    Jul 2015
    Just tried but the cap doesn't turn much . Afraid it will strip the cap . Clockwise sounds backwards . And it only moved a little .
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by jetlau3 View Post
    Hey all
    You might be able to get the thing out, but getting it properly back in by hand would be a pain. What you could do is substitute a flat tool if it's the correct width as it doesn't need any real torque. Just enough to take the play out and have it spin freely should do.
    Access the hex bolt? There's no hex bolt hiding behind there. There are 2 bolts facing each other that need to be loosened and a plastic spacer that's pinched between them. That needs slid/flipped upwards (one end is hooked over the end of the spindle to help keep it coming out if the bolts loosen). After that the arm should be easy to pull off. If the drive side is a little snug, give it a tap or 2 with a rubber mallet and done.
    Clockwise is backwards. That'll tighten it if it moves at all.
    Here's a vid showing how just in case. It's a road bike, but it's the same mechanism.
    https://www.youtube.com/watch?v=2bMyl0dcDW4
    Jul 2015
    Shit went clockwise and prob tightened it . Can't get it out with no tool . May stop by store tomorrow to pickup a tool or just have them remove the cap
    Reputation: J.B. Weld's Avatar
    I've used a big flat head screwdriver in a pinch, you'll need a tool to tighten it anyway.
    Feb 2015
    Those things don't take much torque, but they can get pretty badly seized. I would definitely get the correct tool. They're cheap.
    Jun 2010
    Sorry, had 1 too many beers when i wrote it and left the counter off the clockwise. Even with the correct tool, those things wont budge unless you loosen the pinch bolts first and then it doesnt take much to loosen it.
    Reputation: Robg68's Avatar
    Oct 2013
    You can use a dime and a pair of needle nose pliers to remove and adjust the end cap on the non drive side crank arm
    Reputation: SteveF's Avatar
    It doesn't need to be very tight--I just stick a finger in it, wrapped in a thin shop rag, to tighten. Removal is the same. Or use the handle of a small screwdriver, also with a rag wrap...and yes, do loosen the pinch bolts first. (but tighten the arm cap before tightening the pinch bolts when re-installing)
    Need the tool and wrench to get it off. The cap just preloads so shouldn't be tight but can be
    Personally, I'd really suggest just getting the tool. It'll make the job easier and it's cheap.
    https://www.google.com/shopping/prod...KfBoXtefyguKAO
    since 4/10/2009
    Reputation: Harold's Avatar
    Just get the correct tool. Shimano's is just plastic, though I have seen some companies sell colorful machined anodized aluminum ones. It's cheap. Really cheap. If you have any Shimano cranksets, there's really no reason not to have one of these.
    Jul 2015
    Thanks all! Ordered the tool online. Didn't want to wait so I brought the bike into my LBS and they removed the cap and installed the raceface 30t chainring for me. Finally done with the conversion and ready to ride. Appreciate all of your tips and help.
    Nov 2014
    Found this thread via Google. I can confirm the dime and pliers trick works on the cap. I was able to get the BB shell off using channel locks and an old sock. I have the Park tool to get these back on, but had to get the BB out pronto while traveling.
  1. Help removing CrankSet
    By Am92 in forum 29er Bikes
    Last Post: 10-21-2014, 05:26 AM
  2. Removing Crankset advice needed!
    By Am92 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-20-2014, 05:35 PM
  3. Removing crankset without puller?
    By ou2mame in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2014, 07:48 PM
  4. Help - Removing LX Hollowtech Crankset
    By Mud in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2012, 10:35 PM
  5. HELP: Removing A Square Spline Crankset & BB
    By Hawgzilla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 05:22 PM
Members who have read this thread: 9
