Results 1 to 3 of 3
    Reputation: stingray's Avatar
    Mar 2014
    removing crank arms from TruVativ Powerspline Bottom Bracket
    Any advice or videos describing how to remove crank arms from a TruVativ Powerspline Bottom Bracket like the one in the photo?
    Attached Thumbnails Attached Thumbnails removing crank arms from TruVativ Powerspline Bottom Bracket-photo-nov-28-17-41-06.jpg
    Positively negative
    The bb pictured is ISIS, for ISIS you will need a Park CCP-44 or similar.
    A Power Spline bb/crank arm uses the same tool as a square taper, Park CCP-22 or similar.
    Though both actually use the same technique, How to Remove and Install a Crank - Park Tool.
    Mar 2014
    Thanks for properly IDing it as ISIS. The Park video you recommended was super helpful. It turns out that I have the CWP-7 tool, but forgot the washer stored on the end of it is removable for when needed, like on an ISIS crank.
  1. Replies: 6
    Last Post: 01-28-2015, 10:28 AM
  2. Removing crank arms
    By DirtyBacon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2014, 05:33 PM
  3. Bottom bracket for 73mm BB shell using a spacer compatible with truvativ crank
    By Ponchus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-13-2014, 06:57 PM
  4. Looking to upgrade my powerspline bottom bracket
    By EricBE2013 in forum 29er Components
    Last Post: 07-31-2013, 04:07 AM
  5. Play between Truvativ GXP bottom bracket and crank spindle?
    By uwprunner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-02-2013, 07:47 PM
