Recommendation for 9-Speed chain with Chainrings without Shift Ramps and Pins ...- Mtbr.com
Results 1 to 12 of 12
    New question here. Recommendation for 9-Speed chain with Chainrings without Shift Ramps and Pins ...
    Hi All,
    I will be changing my Chainring configuration as follows for a 104/64mm spider on a Specialitiés Carmina Crank. The rear cogset is 9-Speed 11-34T.
    Inner: Blackspire Chuck Ring 22t (Stainless Steel)
    Middle: Surly 34T (Stainless Steel)
    Outer: Specialitiés Chinook 7075-T6 Al 46T
    Is there any particular chain you would recommend for the above configuration? Will any 9 Speed chain be sufficient? Or are there some that will shift better with chainrings that do not have shift ramps and pins?
    My current configuration uses Race Face Al Chainrings (24-36-48) with an XT 11-34T cogset and a KMC X9 SL Chain. The upshifts (small to large cogs) at the back aren't that smooth nor quiet and I have problems at the front too which I think is due to the bottom bracket axle being too long (122mm). I will also be changing the BB to one that is 118mm.
    I have a similar configuration (no shift ramps and pins) on my old rigid bike which has a 7 Speed cogset (13-34T) and the front shifts very well.
    Thanks, Michael.
    New question here.
    Bump.
    Reputation: tomacropod's Avatar
    I don't think you'll notice a difference between chains. You can get 34t ramped chainrings though, unless you're really attached to the Surly for some reason? TA, Blackspire and Middleburn at the very least will do a 34t middle ring.
    Non-indexed shifters will shift the best, SRAM gripshifters work too, I've used unramped rings with these. Shimano/SRAM trigger shifters may be hard to set up.
    - Joel
    Cycling is Serious Business.
    Caution;  Merge;  Workers Ahead!
    Quote Originally Posted by tomacropod View Post
    - Joel
    Hi Joel,
    My old rigid bike uses indexed shifters.
    The reason I want the Surly is because it's Stainless Steel and they can be flipped over to double the lifespan.
    The 36T middle, I currently have, is looking worn.
    Has anyone used an IRD Pro 991 Hollow Pin Chain?
    Thanks, Michael.
    Former Bike Wrench
    Without ramps or pins, it really isn't going to make that much difference up front, but you still want a durable chain that shifts well then KMC or Shimano (with a Power-Link) are excellent choices.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mtbvfr View Post
    Hi Joel,
    Thanks, Michael.
    I use mid-level SRAM chains.
    Avoid hollow pin chains.
    mtbtires.com
    What FD are you using for the 48 tooth ?
    New question here.
    Quote Originally Posted by jeffscott View Post
    Hi Jeff,
    My Front Derailleur is a 1994 or 1995 Shimano XTR.
    Why do you ask?
    Thanks, Michael.
    New question here.
    Quote Originally Posted by shiggy View Post
    More info please Shiggy?
    Thanks, Michael.
    Hi Jeff,
    Why do you ask?
    Thanks, Michael.
    Oh I run a 46 tooth Front ring and an 2004/5 XTR FD.....
    I would like to go to a 48 tooth just wondering if my FD is gonna work...I think so????
    Dec 1998
    Thanks, Michael.
    More expensive, more likely to fail.
    mtbtires.com
    I think I read somewhere, once, that later FDs usually cater up to 44T and or there is a tighter limitation regarding the difference in the number of teeth between the inner and outer chainrings.
  1. Chainring with no shift ramps and pins
    By p0r0y in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2011, 04:20 PM
  2. Removing chain ring ramps and pins for 1x9
    By isleblue65 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-18-2010, 04:41 PM
  3. who all manufactures "race geared" chainrings? 26, 27. 36-40t with ramps/pins
    By 2silent in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-19-2009, 10:00 PM
  4. Q: shift ramps and pins on middle chainring ?
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2005, 06:18 PM
  5. Dual Chainring Gearing, Shift Pins/Ramps, etc.
    By ryanc44 in forum Downhill - Freeride
    Last Post: 09-24-2004, 03:03 PM
