Results 1 to 10 of 10
    Apr 2015
    Question about rear derailleur for 1X11
    Will a Shimano XT M786 long cage 10 speed derailleur work with the new XT 11 speed cassette and a 32T front ring? I haven't tried it but with the range meant to handle 3X10 I'm hoping it works.
    Blurry SnowMonster
    Jan 2015
    My current setup is 1x10 with XT M786 RD and a 42T cog. To make the RD work with the 42 plate, I installed a RADr cage from OneUp.
    Without it, there isn't enough chain around the 11t cog and the B screw has to be all the way in to clear the 42.
    It's possible the RD will work on 11s since the indexing comes from the shifter, but the new M8000 has a different positionning for the pulley wheels to make it work.
    Dyslexics of the world! Untie!
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by jgdblue View Post
    Other way around, get an 11 spd m8000 der to work with your 10 spd setup if you're trying to get extn'd cog/cassette setup.
    Wait whuuut, who did he tell you that!?!?....
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    A Wolftooth Goatlink is a cheaper alternative to the Rad cage.
    I got some bad ideas in my head.
    NedwannaB
    Quote Originally Posted by Travis Bickle View Post
    Unless I'm missing something(and there's some missing info we could use...) the point the OP is trying to use a 10 spd derailleur on an 11 speed 40t cassette. Not sure if they also have an 11 spd shifter?? either way can't see that functioning.
    Anytime. Anywhere.
    I have a XT 10 speed derailleur, RADR cage, 11 speed XT cassette, and XT 11 speed shifter that all work together wonderfully. I believe the Goatlink accomplishes the same thing as the RADR but is cheaper.
    NedwannaB
    Wow that's cool so you CAN mix-match the 10&11 Shimano stuff. So the ders follow the shifter since pull ratios of shifters are same. Any reason you didn't just get the 11 spd derailleur? Just curious.
    Anytime. Anywhere.
    Quote Originally Posted by JMac47 View Post
    I recently went from 10 to 11 speed and there was no reason to buy a new derailleur as well.
    Nov 2015
    When adding the XT cassette do you also need to purchase the XT 11 speed chain?
    Sent from my SCH-I545 using Tapatalk
    NedwannaB
    ^^Subscribed^^
  1. GX 1x11 Rear Derailleur with X9 10speed issue
    By east_coaster in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-25-2017, 01:40 AM
  2. Question regarding rear derailleur and rear brakes
    By Kerrslight in forum 29er Components
    Last Post: 08-11-2015, 03:01 PM
  3. Rear Derailleur question
    By dpo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2012, 09:03 AM
  4. Rear Derailleur Question and HELP!!!!!!
    By boxedrn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2011, 07:43 PM
  5. another front/rear Derailleur question(s)
    By wangmauler in forum Beginner's Corner
    Last Post: 04-18-2011, 07:54 AM
