PressFit 30 Bottom Bracket for 24mm axle cranks- Mtbr.com
Results 1 to 3 of 3
    Jan 2011
    For everyone suffering the PF30 BB. Recently installed a Wheels Mfg. Outboard PF 30 BB for 24mm cranks. Can not say enough about the quality and design. The two halves thread together for a very positive/tight fit.
    Reputation: aliikane's Avatar
    Quote Originally Posted by Dambala View Post
    I have been looking at Wheels Manufacturing and RWC for a better solution than the OEM BB.
    Did you need a press-fit tool to install?
    What material is your frame (carbon or aluminum)? Does it look creak-free?
    Jan 2011
    Quote Originally Posted by aliikane View Post
    You will want to use a press-fit tool (or the home made threaded rod and washer trick) to make sure the BB halves go in straight.
    My frame is Alum but I would not hesitate to use it on a carbon frame. It has been silent so far and the way it is designed and Mfg I expect it to remain creak free, I got the angular contact bearing version which spins remarkably well.
  1. Pressfit 30 Bottom Bracket - Delrin vs Aluminum Sleeve
    By tiflow_21 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-12-2013, 02:08 PM
  2. Replies: 1
    Last Post: 11-10-2013, 10:59 AM
  3. Which bottom bracket for pressfit?
    By bluesrider in forum SRAM
    Last Post: 07-30-2013, 09:59 AM
  4. Token bb92 pressfit & cranks with no integrated axle
    By mayathebee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2013, 06:40 AM
  5. bb30 bottom bracket pressed into a Pressfit 30 (PF30) frame
    By trail rida in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2013, 10:19 AM
