PG 990 versus PG 980- Mtbr.com
    Enthusiast
    Reputation: JonathanGennick's Avatar
    What exactly does one get with SRAM's PG 990 cassette that doesn't come with the PG 980? I'm looking at the following two items, both 2010 models:
    Sram PG 990 9 Speed Cassette '10 at JensonUSA.com
    Sram PG 980 9 Speed Cassette '10 at JensonUSA.com
    Weight wise, they are virtually identical. Jenson lists the 990 at 305 grams for the 11-34 model, and the 980 at 304 grams for the 11-34 model. The cheaper unit is a gram less. Given that the weights are the same, why would I want to pay more and buy the 990? There must be some advantage to the 990 over the 980, and I'm just not seeing it. What is it?
    Reputation: boomn's Avatar
    The 990 11-34 has the six largest cogs on an aluminum spider and the the 980 only has the three largest on a spider. It's surprising the weight difference isn't bigger, but I've seen it confirmed before. If you have an aluminum freehub then you definitely want the 990. The three cogs that aren't on the spider on the 980 are still large enough to dig in to the freehub.
    Fat-tired Roadie
    Nov 2007
    The 990 comes in pretty colors.
    Enthusiast
    Quote Originally Posted by boomn View Post
    Thanks! That explanation helps a lot. It probably saves me money too. I'm going to doublecheck, but I'm pretty sure that my son's hub is steel.
  1. My 575 versus ASR 5 C
    By AussieBunyip in forum Yeti
    Last Post: 05-21-2010, 03:58 AM
  2. galvanized versus stainless versus teflon-coated
    By JonathanGennick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2009, 02:44 PM
  3. gary fisher tassajara versus kona caldera versus kona cinder cone
    By twilliams in forum Bike and Frame discussion
    Last Post: 05-15-2008, 10:26 AM
  4. Replies: 21
    Last Post: 07-14-2007, 12:18 PM
