Results 1 to 5 of 5
    May 2013
    One Up 45 tooth sprocket??
    Was thinking about trying this behemoth. Those of you that are using it I would like to hear how it's working out?? Are you able to use a medium cage derailleur? What front ring did you change to after adding the 45t?
    RHRF!
    Reputation: titusbro's Avatar
    Quote Originally Posted by kingchickenstrip View Post
    Current setup -
    XT 11-40 cassette
    1-Up 45T
    XT Medium Clutch RD - Stock B-Tension
    XT 11-Speed shifter
    RF N/W 30t
    KMC X11SL chain
    Best shifting setup I've had in a long time!
    "The secret of joy is the mastery of pain." (Anaïs Nin)
    Reputation: Davide's Avatar
    I am using it with:
    XT 11-40 cassette
    1-Up 45 & 18
    XTR 11 shifter
    Garbaruk 30 Oval Chain ring
    Shimano XT chain
    Works perfectly. One thing to consider before you go that route is that Shimano might come in with a 1146 (XT? XTR?) cassette this year Spy Shot: Prototype 11-46 Wide Range Shimano Cassette
    May 2013
    Wow the 45 tooth was sold out on One Up's web site. I found it at Jenson USA and ordered it.
    I was using a 32 tooth chain ring and will be switching to a 34. Looks like a lot of good reviews, cant wait to try it!!
    May 2013
    So I ended up getting the 45 tooth one up sprocket and used it with my XTR 11 speed cassette. Up front I am using a one up 32 oval chain ring. Installation and adjustment was super easy!
    Coming from a previous one up 10 speed conversion I was a little scared to hack a new XTR setup with the one up monster ring. I was not disappointed! The shift quality was amazing, I never have to worry about it now. For me the 45 and 32 oval up front is as low as I will ever need to go. So I am very happy.
    The only negatives are the weight, over 400 grams for the cassette after the 45 tooth is added. Second is I would like something lower than an 11 tooth on the cassette. I have been eyeing the E-13 11 speed cassette, it has the 9 and 10 speed gears I would like and is 100g lighter.
  1. 36 tooth to 32 tooth sprocket
    By mcbike420 in forum Downhill - Freeride
    Last Post: 10-19-2015, 07:54 PM
  2. Setup prob with Hope 40 tooth sprocket (XX rear derailleur), please help.
    By <Steven> in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-13-2015, 09:35 PM
  3. One Up 42 tooth cassette sprocket
    By rlewis in forum Fat bikes
    Last Post: 12-02-2014, 01:06 PM
  4. Replies: 0
    Last Post: 05-29-2014, 10:54 AM
  5. 38 tooth rear sprocket feed back required ?
    By fat arse racing in forum General Discussion
    Last Post: 04-16-2013, 11:10 AM
