Results 1 to 6 of 6
    Dec 2015
    Off center bottom bracket
    Hello, this may be a very simple question but I can not figure out why my shimano un 26 bottom bracket is not centered. I first noticed that my front derailleur would not properly shift into the smallest ring because it was maxed out. I then noticed that my drive side crank was about a quarter inch closer to the chainstay than the other side. This leads me to believe the bottom bracket is off center but I don't know what the fix is. Any help would be great thanks.
    Life's a ride, enjoy it! Moderator
    Reputation: life behind bars's Avatar
    May 2014
    Asymmetrical chainstays?
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Feb 2014
    try using spacers
    Nov 2015
    shimano makes offset bb's, I have one that pushes the chainline out to 52 or 53 mm. I found it in a bin at the local co-op and used it on a janky ss conversion to get a straight chainline. I have to admit having the drive side shorter sounds weird, like its a 68/73 in a 83 shell or sumthin'
    Maybe a 73 mm BB in a 68 mm shell?
    Dec 2015
    Quote Originally Posted by tiretracks View Post
    Good question. I am a noob. I assumed it was but I have no idea. I just figured since the derailleur also wasn't working it must be the bb.
    So what spacers do they fit in between the bb and drive side crank or are they spacers that move the bb.
    Thanks for the help.
  1. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  2. Bottom Bracket
    By BrianBro in forum 29er Components
    Last Post: 03-15-2015, 07:42 AM
  3. Replies: 6
    Last Post: 10-31-2013, 07:26 PM
  4. Jet 9 bottom bracket
    By ThinBlueLine in forum Niner Bikes
    Last Post: 04-19-2012, 10:40 AM
  5. Slr bottom bracket?
    By sohnice in forum Ibis
    Last Post: 09-29-2011, 11:13 PM
