Results 1 to 5 of 5
    Reputation: apache's Avatar
    Need XT M8000 shifter confirmation
    Hey Guys,
    Can someone help confirm that the correct XT 8000 shifter for a BL-M875-B XT brake is the Shimano XT SL-M8000 shifter, correct?
    I got the wrong damn shifter (i-spec II).
    Thanks Guys
    P.S. (and no thanks to you Shimano with all your ridiculous standards)
    B A N N E D
    Bar Mount = SL-M8000 https://www.bike-components.de/en/Sh...l-2016-p43929/
    I-Spec II = SL-M8000-I https://www.bike-components.de/en/Sh...l-2016-p43933/
    I-Spec B = SL-M8000-B-I https://www.bike-components.de/en/Sh...l-2016-p43931/
    Bar mount shifters can be used with any brake lever because they attach directly to the handlebar with a clamp, get the I-Spec-B shifters if you want to attach them to your brake levers.
    Quote Originally Posted by cobba View Post
    Perfect, thanks!
    B A N N E D
    * This could be a problem if you ever want to upgrade your brakes, Shimano seems to be phasing out the I-Spec B, the current model XT & XTR are only I-Spec II.
    Buy the Hope HBSP327 and mount your I-Spec II shifter to your I-Spec B brake. The only issue is that you have to drill a larger hole in the Hope adapter and cut down the I-Spec B nut a little. Other then that it works perfectly and requires no modification to either the shifter or brake lever, just the Hope adapter and I-spec B nut need modification.
    http://forums.mtbr.com/drivetrain-sh...on-996480.html
  1. Xt m8000 shifter with ispec B brakes
    By Levi707 in forum Shimano
    Last Post: 12-07-2016, 05:59 AM
  2. $33.97 OEM Shimano XT M8000 11 rear shifter Crosslake Sales ebay
    By Honda Guy in forum Where are the Best Deals?
    Last Post: 11-24-2015, 06:54 AM
  3. XT M786 Rear With 11 Speed M8000 Shifter
    By Travis Bickle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2015, 09:48 AM
  4. XT M8000 Cassette with SRAM shifter/derailleur
    By Triggsie in forum Components
    Last Post: 09-27-2015, 12:25 PM
  5. Will shimano XT cassette M8000 work SRAM X01 derailleur + shifter?
    By egr551 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2015, 07:45 AM
