Results 1 to 6 of 6
    Reputation: apache's Avatar
    Need XT M8000 Derailleur Install info.
    Hi Guys,
    I can't find any instructions or specific videos on installing the XT M8000 RD. I don't know if there anything peculiar about the installation of the RD (like some SRAM RDs).
    So, is the correct method to align the pulley wheels exactly inline with the tallest and shortest cogs? Anything out of the norm with B screw adjustment?
    G
    Aug 2015
    I did nothing different when installing mine. Set L & H as per normal. Had to adjust the B screw to clear the 42T a bit. Attached cable and made small barrel adjust on the shifter. Happy days!!
    Quote Originally Posted by WrightJnr View Post
    Thanks for the input!
    G
    Aug 2015
    No problem. Be patient and spend time setting up. I've found the 11 speed to be very very fussy. Settings are critical. I put it down to the tighter tolerance to accommodate the extra cog. Indexing must be 100%
    Professional Slacker
    Quote Originally Posted by apache View Post
    Hi Guys,
    G
    Yes, and 5-6mm from the pulley to the biggest cog.
    Reputation: spyghost's Avatar
    Oct 2012
    from experience its as normal...
    Canfield Yelli Screamy
  1. Replies: 9
    Last Post: 11-16-2017, 07:41 PM
  2. XT M8000 Cassette with SRAM shifter/derailleur
    By Triggsie in forum Components
    Last Post: 09-27-2015, 12:25 PM
  3. M8000 rear derailleur adjustment issue
    By Adodero in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-14-2015, 12:59 AM
  4. Any info on when the Shimano m8000 11-42 cassette will be available?
    By SB666 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-11-2015, 10:38 AM
  5. XTR M9000 rear derailleur with XT M8000 11-42t cog any issues?
    By Yamimoto85r6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2015, 08:57 AM
