Need recommendations on upgrading my crankset- Mtbr.com
    I have a Maverick Durance that currently is running a SLX with the outer ring removed and a bash guard. It is technically a 2x9 but I do not shift to the granny so I run it as a 1x9.
    I am planning to remove the granny and get an e-thirteen ring and chain guide/bash and turn it into an actual 1x9. I was also considering just buying a race face atlas free ride crank with an e-thirteen ring and chain guide/bash and replace my whole crank.
    Lastly I was thinking about the Truvative Hammerschmidt crank.
    I do mostly trail riding/ all mountain with drops and I ride pretty aggressively. I know that I want a 1x9 set up but the hammerschidt looks interesting.
    Can someone help me make a decision or recommend other options?
    Reputation: DavidR1's Avatar
    "The Truvativ HammerSchmidt All Mountain Crankset will only mount on frames with ISCG 03 or ISCG 05 tabs". I don't believe your frame has these tabs, but I could be wrong.
    The SLX is a nice crankset. It is easy to remove the inner chainring and make it a 1X9 if you want.
    CyclingCentralVa.org
    I saw someone else on the Maverick section of the forum, someone with the same frame as me had a hammerschmidt, that it what made me think about one.
    Reputation: Shalom's Avatar
    Nov 2008
    If it were me, I would save my money. Make your existing crank a 1x. Remove all rings, install guide ring, install chain guide (eg e13 XCX or MRP 1.x) and be done with it. Works well and is a lot cheaper than an Hammerschmidt.
  1. Upgrading to XTR crankset
    By GiantMartin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2009, 09:31 PM
  2. upgrading crankset/bb
    By vw3vr6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-27-2008, 07:19 AM
  3. Upgrading my crankset, need advice.
    By Oceaner in forum Clydesdales/Tall Riders
    Last Post: 07-11-2008, 02:11 PM
  4. Upgrading Crankset - Questions
    By mattbryant2 in forum Singlespeed
    Last Post: 04-21-2008, 08:46 AM
  5. Upgrading Deore crankset to XT worth it? Or Upgrading Cassette / Chain?
    By krayzie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-04-2005, 05:00 AM
