Need recommendations on crank, rear derailleur, and shifter...- Mtbr.com
Results 1 to 5 of 5
    nattyboh74
    Guest
    Im looking for a medium cage derailleur that can take a beating, along with a shifter for it. I also am in need of a 68mm, 170mm length crankset. Im going to run a bash guard and an e.13 on it. So just one chain ring up front ( 32 is possible )
    Im not sure whats out there and whats out there for what Im looking for in a crank. Id like to spend around 250 and I'd like it to be for FR/AM use. So more so AM then FR. Id like to shave a few grams too if possible.
    Mar 2011
    If you're on a budget and want a 32T Chainring then you could get a second hand triple SLX or XT crankset in which the middle is 32T just ditch the granny and big ring and add the bash - you won't get any chainline / clearance issues that way with the standard hollowtech II BB setup. Up to you whether to go with SRAM or Shimano - for the shifter / RD but X7/X9 or SLX / XT are all good and solid - I have both XT and X9 set ups on different bikes and I like them both. I think SRAM make the shortest cage RD's
    nattyboh74
    Guest
    Would going to a 36 chainring hinder my ability to climb on a 1x9 with an 11-32 in the rear? should I drop drown to a 32?
    Quote Originally Posted by nattyboh74 View Post
    It will be tougher to climb with the 36. Whether it will be too hard depends on your preferences, climbing ability and the terrain.
    Jun 2010
    This is a nice deal on a new crankset, just need to buy a non-ramped ring.
    Shimano SLX FC-M66010 Dyna-Sys MTB Crank at JensonUSA.com
    X7 or X9 RD/Shifters.
  1. What rear derailleur and shifter?
    By Natedogz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2009, 05:39 PM
  2. What rear derailleur and shifter?
    Last Post: 07-03-2009, 05:36 PM
  3. Shifter - Rear Derailleur Compatibility / LX SL-M580 9spd Shifter with XT M761-SGS
    By mtbvfr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-31-2009, 10:45 PM
  4. Replies: 0
    Last Post: 05-29-2009, 08:03 AM
  5. rear shifter and derailleur
    By TrailNut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2008, 09:48 AM
