Need help finding- Mtbr.com
Results 1 to 6 of 6
    Reputation: jeremyreed's Avatar
    Jan 2014
    Need help finding
    Converting my 3x8 to 1x8 and having trouble funding a crank and bb set compatible with 8 sp...please help
    JREED
    9 speed will work fine. For that matter, since you are going 1X pretty well any crankset with removable rings will work. Avoid a double crank, the chainline isn't as good.
    Jan 2014
    Going to lbs..I talked to a guy there.He is gonna look at my bike.think we are gonna get a crank with removable rings and take 2 off
    JREED
    You should take all 3 rings off and replace the single ring with a single speed or narrow wide ring. The rings that come on the crank will drop the chain too easy - they are designed to derail the chain for shifting. Sell the new rings that came on the crank.
    Jan 2014
    Ok
    JREED
    Reputation: Fuglio's Avatar
    Your down grading. there is nothing wrong with 3x8. and by going 1x youll have less high end and low end gearing youll need a chain device or an expensive front ring. All to have less gearing options. Why are you going 1x again??
  1. Finding the new....
    By azepicriderandrunner in forum Arizona
    Last Post: 02-19-2013, 09:57 PM
  2. Finding the right LBS
    By pointerDixie214 in forum General Discussion
    Last Post: 09-12-2012, 07:55 PM
  3. Need help finding which BB I have.
    By scootnandbikin in forum 29er Bikes
    Last Post: 09-10-2012, 04:07 PM
  4. need help finding a rack
    By kjbiter in forum Cars and Bike Racks
    Last Post: 08-20-2011, 05:22 PM
  5. Finding a good LBS is like finding a good mechanic
    By bank5 in forum General Discussion
    Last Post: 05-16-2011, 07:11 PM
