    Aug 2015
    Need help with Blackspire chainring bolts
    I just ordered a Blackspire 28T chainring for my Sram XO1 1x11 drivetrain. I called Blackspire up to make sure no compatibility issues. The guy over the phone told me to use my existing Sram bolts. Well, as you can see they are no where close to being compatible. Does anyone know what bolts are to be used with this chainring? Thanks!
    Attached Thumbnails Attached Thumbnails Need help with Blackspire chainring bolts-img_3500.jpg
    Jul 2017
    Are you sure itís the same BCD?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Looks to me like the Black Spire chain ring has the chain ring nuts integral to the ring. You stick it on so the protrusions go into the spider and the bolts then thread directly into the chainring to fasten it.
    Do the math.
    Apr 2018
    The Blackspire chainring is threaded. Unscrew the bolts from the nuts used with the old one and they should thread directly in the Blackspire.
  1. Using disk rotor bolts instead of SRAM direct mount chainring bolts
    By agu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-08-2016, 07:13 AM
  2. Replies: 18
    Last Post: 06-02-2011, 07:14 PM
  3. Blackspire Stinger- Anyone else have to grind down bolts?
    By CharacterZero in forum Downhill - Freeride
    Last Post: 02-21-2008, 06:05 PM
  4. Chainring replacement: lube chainring bolts?
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2006, 11:35 AM
  5. bolts bolts bolts
    By gic in forum Weight Weenies
    Last Post: 08-26-2004, 11:56 AM
Members who have read this thread: 18
