MRP 1.X Direct Mount- Mtbr.com
Results 1 to 47 of 47
    Jun 2010
    anyone know where I can buy one of these?
    Attached Thumbnails Attached Thumbnails MRP 1.X Direct Mount-p4pb4889931.jpg
    Quote Originally Posted by olddirtygt
    sorry no help, but Id LOVE to find out too. looks simple, and LIGHT! just ordered an ethirteen for like $45 but Id sell it for less if I could get one of those. except, what does it mount to? Im guessing a seat tube bracket?
    Jun 2010
    it mounts where the FD mounts (shimano direct mount).....my frame (HIFI) won't allow a jump stop or inner bash guard. was wanting to go 1x9.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I'd fire off an email to mrpbikes.com and ask them. They don't show that part on their site, but it obviously exists. I wonder whether they made an OEM batch.
    Reputation: JSumner13's Avatar
    I'm looking for the exact product.....trying to turn my Gary Fisher Rumblefish (same design as your hifi) into a 1X9 and this would be the ticket. If anyone finds this product please let me know. Thanks!
    sorry OP, this doesnt help you either but.....just found this. not it but its similar and available.
    http://www.jensonusa.com/store/produ...in+Keeper.aspx
    Unfortunately the clamp on style guides will not work with the hifi/rumblefish due to the suspension design. I contacted MRP about the Direct Mount 1.X and they said that the product should be in stock around mid October...good news olddirtygt
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    http://www.paulcomp.com/ckbb.html
    Problem solved. Take 5 min with a grinder and you could use it with a bashring. The 1x sucks, no ability to run bash.
    I am immune to your disdain.
    Reputation: alex_k's Avatar
    Quote Originally Posted by indyfab25
    What was the problem? You can use "jump stop" with a bash ring setup: http://www.treefortbikes.com/product...op--349mm.html. It is cheaper and does not need any modifications.
    I run a solid downhill chainring so don't need a bash ring at all. And believe me MRP 1.x has better design for riding small drops, log, jumps and etc. I tried them both.
    Quote Originally Posted by alex_k
    The chain will not stay on my bike(Blur 4x, LT2, LTc) with an N Gear. The N-Gear is great for hardtails but is wildly inefficient for my riding style and bikes. The chain pops up and over the guide and it is super flimsy. I wrecked 4 of them. Cheap yes and cheap they are.
    I like security and piece of mind running my gear. There is not a single ring upper guide that takes a bashring on the market.
    i ride bikez!!11!
    That will only work with threaded BBs, not any pressfit. I'm pretty sure that any Hi-Fi that has a direct mount front derailleur also has a BB90 setup.
    Quote Originally Posted by xmynameisdan
    Problem not solved!
    Problem not solved!
    you should just do the chain wheel sandwich then. bashguard on inside and outside. have you seen that setup? most people just make there own inner and outer bashguards with lexon from home depot.
    meow meow
    Reputation: b-kul's Avatar
    i think that was a prototype, never released.
    Quote Originally Posted by irocss85
    This won't work on the hifi/rumblefish either due to chainstay clearance
    Quote Originally Posted by b-kul
    MRP will be releasing them mid October
    May 2010
    Anybody come up with a decent inexpensive (<$25) solution? I am also looking to go to 1x9 on my 2010 Hifi.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    The FD-mount 1x (still forthcoming, sorry guys) is likey the best solution for the Hifi. The pressfit BB eliminates just about any other option. The FD-mount 1x will run $69.95 when it is released.
    1x FD on GF Superfly
    Cheers
    NOAH SEARS
    MRP - VP of Business Development
    Quote Originally Posted by NoahColorado
    Cheers
    $70.00!!! That's absolutely rediculous. The BB mount 1X is can be had for $35.00
    May 2010
    Quote Originally Posted by JSumner13
    Yeah, that is pretty pricey in my book too. But apparently the choices are pretty limited... as in one.
    Looks like I might have to just use my front derailleur and put a longer screw in it. Maybe I can wrap it in gorilla tape so it isn't so noisy.
    70$ is the retail the BB mount retail is 50$, you'll probably be able to find it cheaper once it comes out.
    Reputation: dhbomber's Avatar
    Nov 2006
    Is that Rust on the swingarm of the Superfly!!!!
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    Registered Dietitian
    Reputation: tommyrod74's Avatar
    Jul 2002
    Caution;  Merge;  Workers Ahead!
    Does anyone have a homemade solution to this problem? I have a 2011 Superfly Elite hardtail frame on the way... and I've run 1X9 for 2+ years now on my 2009 and 2010 SF frames, so I don't want to run a front derailleur. I have a MRP 1.X bottom bracket mount version, so I could use the plastic part of that and rig a mounting mechanism, maybe... any ideas?
    Registered Dietitian, Cycling Coach, Ascend Nutrition and Coaching
    www.ascendthepeak.com
    www.facebook.com/ascendthepeak
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by rdaled
    Two. The e.thirteen XCX-ST is similar, but will set you back a whopping $99.95
    From the photos, the MRP 1x looks like the sturdier product, and a comparative bargain.
    Old enough to know better. And old enough not to care. Best age to be.
    Quote Originally Posted by dwt
    The e.thirteen isn't direct mount so it won't work on the Hifi/Rumblefish
    homemade solution
    Quote Originally Posted by tommyrod74
    Here's what I've been using while I wait for the MRP version to come out.
    It's an Avid 185 post mount adapter with a couple of star washers to keep it from rotating.
    So far so good - It's been on my Rumblefish for about 8 months now, including a month getting smacked around on the Whistler valley trails.
    The bottom bolt needs to be pretty tight, however, and the cage is starting to crack - so I'm sure the MRP version with a guide slot is going to be better.
    I'm going to buy 2.
    Attached Thumbnails Attached Thumbnails MRP 1.X Direct Mount-directmount_homemade_2.jpg
    Jul 2002
    Quote Originally Posted by donburg
    I'm going to buy 2.
    Thanks for the idea! That was an ingenious way to make it work for a while. I'm going to try that with mine; might need a smaller adaptor (160mm?) due to a larger single chainring (36-38t depending on course).
    GUIDANCE COUNSELOR
    I'm going to buy 2.
    Well done sir, well done. That's pretty awesome!
    NOAH SEARS
    Well done donburg. Why couldn't you use the BB-mounted version?
    Quote Originally Posted by alexkraemer
    Press fit bottom bracket
    Gotcha.
    Reputation: aabbas's Avatar
    May 2005
    Pauls said that they're developing a version of their Chainkeeper that will bolt on to derailleur mounts.
    May 2010
    My Solution
    Made this piece at work out of 14ga. stainless steel...
    Looks like this on the bike...
    Does it work??? YTBD
    Reputation: zenboy99's Avatar
    Feb 2007
    Any word on when the MRP direct mount chain guides will be available? I'm looking for one for my Big Top
    GUIDANCE COUNSELOR
    Thanks for your patience, I know everyone has been waiting for an eternity for these! They are in production now, they will be shipping by late February.
    NOAH SEARS
    Reputation: ejreyes6's Avatar
    Dec 2010
    I just ordered a direct mount from MRP today. I hope to have it by friday.
    I'll post pictures as soon as it comes in.
    Feb 2007
    I don't see it on their website?
    Dec 2010
    Call them directly. I talked to Tim Fry
    GUIDANCE COUNSELOR
    Quote Originally Posted by zenboy99
    You'll see an entirely new website soon.....
    Shimano FD-Mount 1x guides are now available.
    NOAH SEARS
    Dec 2010
    Just finished installing the guide on me 11' Rumblefish.
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Quote Originally Posted by ejreyes6
    And where did you obtain that, if I might inquire?
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
    Feb 2007
    I talked to MRP directly last week and recieved mine on Tuesday!
    I'm putting it on my Yeti Big Top tonight, I'll post up pics
    Ka-coo-ka-cha!
    Feb 2010
    Sweet, that's perfect! I have a Big Top that I am going 1x9 on...how much from MRP direct?
    Dec 2010
    $70
    Reputation: Noclutch's Avatar
    Jun 2010
    So there is nothing other than Rdaled's solution out there for this application ( guide for use with with bash on these GF's) ??
    rdaled- you wanna make another one of those?
    ejreyes6- do you think is one were to source shorter front bolt for the guide( and just toss the rear one), just the inner 1/2 poly peice could be used by itself, thus allowing bash clearance but inner drop prevention?
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    What does this piece weigh? Website says 55-70g for 1x guides but doesn't say which model weighs what.
    Herro prease
    GUIDANCE COUNSELOR
    Quote Originally Posted by TheRedMantra
    53.2 g, just weighed, only missing the fixing bolt - so I guess it'd be ~55g with that.
    NOAH SEARS
