Link/Chain Connector for 10sp Shimano Chain?- Mtbr.com
Results 1 to 15 of 15
    Does SRAM Powerlock or KMC Missing Link or any other on/off chain connector work with a 10 speed Shimano chain?
    Reputation: Milkman311's Avatar
    Aug 2010
    KMC MissingLink 10r with XT Cn-Hg94 here.
    Nov 2007
    Quote Originally Posted by Affe View Post
    SRAM isn't on/off. The powerlock is a single use only and can't be dismantled. Go with the kmc.
    Sent from my GT-I9100 using Tapatalk
    Thanks guys for a quick help! KMC that is then.
    A guy on a bike Moderator
    Reputation: TobyGadd's Avatar
    KMC makes great chains too...
    Former Bike Wrench
    +3 on the KMC
    Jun 2010
    They both work. The SRAM powerlock's are much more snug fitting which is why people say they are not on/off. My local bike shop showed me the trick to get them off very easily and I now use them instead of the KMC's.
    Reputation: BacDoc's Avatar
    Quote Originally Posted by cnebrask View Post
    Care to share the trick?
    Jun 2010
    It's kinda hard to explain, but here you go.. You use a pair of channel lock pliers and you put the top of pliers on the very edge of one power link, and the bottom part on the very edge of the opposite power link, then squeeze. I can take a picture if you want to better explain it.
    Here.. If this is the link looking top down, the channel locks need to go in the position of the xx's.. they pliers should not touch the inner part of the link, only the PowerLink.
    ...x
    x
    Jun 2010
    Also, the trick to securing the Powerlock's is to put the link in and pull the chain a little to seat the powerlock. Then turn the crank until the powerlock is on the top of the drive between the cassette and the crank. Hold the rear wheel so it can't rotate then push the crank forward to lock the Powerlock.
    oh ok. thats good to know!
    Karma Vampire
    Reputation: 29Again's Avatar
    Mar 2005
    I have used Connex Link by Wipperman on 10spd Shimano Dura-Ace and 10-spd Ultegra chains. They haven't let me down.
    http://www.connexchain.com/Connector...ink/1_309.html
    They install different than the SRAM link on 8 and 9 spd chains. Here is the Assy & Op Manual:
    http://www.connexchain.com/data-live...onnex_Link.pdf
    NMBP
    Reputation: gfs69's Avatar
    Great tool
    I bought these bad boys to remove the links on my chains, works like a charm: Amazon.com: Park Tool Master Link Plier - MLP-1C: Sports & Outdoors
    Reputation: dcc1234's Avatar
    Nov 2008
    thx for tips. Just tried to get 10 speed Shimano compatible KMC master link to connect to new 10 speed Shimano chain. I couldn't get the link to close all the way- even though I applied what I thought should be sufficient force.
    I haven't put pedals on the bike yet, so maybe it will work if I just apply more force to the crank while holding the rear wheel stationary?
    UPDATE: Put a little light oil on the powerlink this morning and it snugged right up.
    Reputation: SpeedStarr's Avatar
    I use the KMS Missing link and the Park tools link plier. Both work great.
