Results 1 to 3 of 3
    NedwannaB
    Reputation: JMac47's Avatar
    Hi-LO gear loss going 1x11
    What gearing setup are people comparing the loss to from switching from a 2x setup? Currently running a 24/36 granny trying to figure out if 32/40 or 42 would be same or slightly easier gear.
    Wait whuuut, who did he tell you that!?!?....
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by JMac47 View Post
    Neither, you would need to go to 28/42 to equal the low gear you have now.
    NedwannaB
    Quote Originally Posted by J.B. Weld View Post
    Yikes. Really....up til recently been on a 30/11-36 1x setup. I rode a bike for a bit that had a 26/36 granny felt like that's as low as I'd want to grind from here on out @ 58 years young. Really have been enabled by the simplicity of the 1x(also ~50/50 singlespeed use). Ugh. Mehbe I should stick with my 2x.
    *Edit-Or what about oval rings, any experiences on them giving true benefits of matching dropping a couple teeth off of a standard ring?
  1. 1X11 - BIG/BIG backpedal changes gear
    By znerk in forum Tooltime
    Last Post: 06-01-2015, 11:28 PM
  2. 1x11 gear math correct?
    By Calzor Suzay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2014, 06:14 AM
  3. Replies: 32
    Last Post: 09-28-2014, 10:52 AM
  4. Getting my desired gear ratios from 1x10 / my alternative to 1x11
    By regularbob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-24-2014, 05:34 PM
  5. Replies: 3
    Last Post: 05-11-2014, 11:32 AM
