    Oct 2012
    Help with Raleigh Lahar Crankset
    Hey all, please pardon my potentially dumb question but I've done a fair bit of searching to no avail so I figured I'd ask. I have a 2003 model year Raleigh Lahar that I'm looking to convert to a 9 to 1. Taking a look at the crankset I'm a little confused on how I'm supposed to take it apart. It does not have any pinch bolts, but rather one large locking allen key bolt. And I was not able to find a manual for the Shimano Deore FC-M572 crankset anyway.
    I'm able to get that bolt off but I'm confused what to do from there. Do I just try to get the crank arm off with a rubber mallet? Because it does not look like that sucker is going to come off.
    And finally is this a conversion that I'm able to do with this setup? I've included some pictures below to look at. Are there any tools, especially for the BB that I should purchase?
    Raleigh Lahar 2003 Crank - Album on Imgur
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by ChwyNiblet View Post
    You'll need a crank puller that works with splined octilink bb's.
    Oct 2012
    Quote Originally Posted by J.B. Weld View Post
    Got it! Thanks a bunch! As far as a chainring, will any 32 tooth chainring work? I'm assuming they're all the same?
    You will need at least a single speed chainring and a narrow wide chainring would be the best.
    Assuming your crank has a BCD of 104 then any chainring for the BCD will work.
    If you are going 32T, consider a 30T chainring - gives you that extra bit for hills and I find I use more of the cassette, spread the wear over more cogs.
  1. Converting an FSA triple Dynadrive Crankset to a double crankset
    By wheelinthai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2014, 06:20 AM
  2. SRAM S600 crankset or Shimano M410 Alivio crankset?
    By DanHS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2014, 12:05 PM
  3. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  4. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  5. Chainline difference in a 2x crankset vs a 3x crankset?
    By fire_strom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 06:50 PM
