PLEASE HELP ASAP!
i have an Air 9 RDO that requires PF30 BB. Talked to niner and they said take your time, make sure it's flat, no grease...pressed in all the way at LBS, looked ready to roll...Installed SRAM X1 aluminum crank set per SRAM directions re: spacers. Rode it in driveway and BB walked out of frame 1/4"...attempted to re-press and can't get it all the way home (1/16" out from frame) Am I just a ***** and it needs more muscle??
Loctite? To prevent walkout? PLEASE HELP ASAP! I need the tech on exactly how this setup goes together (washers and spacers and preload)
THANKS
