Results 1 to 8 of 8
    Mar 2013
    Granny Sucks, Reverse?
    I have my doubts but wondering if anyone tried reversing a worn ring?
    Positively negative
    If the teeth are not offset you will be fine. I have done it several times. If there is offset you should probably just spend the 15 bucks.
    Mar 2013
    thanks, it's a 20t and I've got plenty of 22s but I'm soft and want to run it with the new chain until the replacement arrives. Starting up the hill yesterday sucked having to go home and change the chain.
    kneecap
    I run hard to get 20 t grannys as well. I've rotated them 180 degrees so that the teeth that were on the top peddle stroke with little wear are now on the down stroke where teeth were worn. lots of life left.
    Quote Originally Posted by kneecap View Post
    Do you mean 90? The crank arms are 180 apart so rotating a ring 180 wouldn't make a change in placement relative to the pedals/cranks/power stroke.
    Nov 2014
    Yeah....180 wouldn't work unless one leg was substantially stronger than the other
    Mar 2013
    Quote Originally Posted by dledinger View Post
    That reminds me my mechanically challenged mother used to say (she was apt to repeat things) she had a stronger left leg because she always wore the left cotter pin
    Anyway I flipped the ring and it plays nice with the new chain.
    kneecap
    Well yeah, meant that I rotated the ring one chainring crank arm space. that is 90*
    Obvious that I wasn't a math major, ha.
  1. Rock Razor in Reverse???
    By project_d in forum Wheels and Tires
    Last Post: 05-19-2015, 05:59 AM
  2. reverse spinning hub?
    By hookydoo in forum Wheels and Tires
    Last Post: 01-16-2012, 08:43 PM
  3. Reverse Rotation ?
    By C.M.S in forum Wheels and Tires
    Last Post: 09-15-2011, 06:48 PM
  4. Reverse Raspberry POV
    By drydirtrider in forum Pivot Cycles
    Last Post: 05-28-2011, 04:03 AM
  5. reverse spam - looking for frame
    By 'size in forum Arizona
    Last Post: 05-17-2011, 05:15 PM
