Results 1 to 5 of 5
    Oct 2015
    New question here. Front shifter problem - only able to use 2 speeds
    Hello
    I wondered what this knob: Name:  eLITM90.jpg
    is good for on my Shimano Deore fd-m610 front shifter and loosened and tightened it today, to see what happens. Afterwards, I realized that I'm now only able to change between 2 speeds, the big chainring and the middle one. When I'm trying to downshift on the small chaining, the shifter does not click. The downshifting-lever moves towards the handler bar, but nothing happens. The red indicator also remains in the same place(middle). I tried to adjust the knob in all ways but could not get it back. The bike is pretty new.
    Any thoughts ?
    May 2015
    Is there a switch on the bottom of the shifter to change it from 3x mode to 2x mode? If not, you've probably just mucked up the cable tension and it needs to be readjusted.
    May 2015
    SL-M610-L does have a mode converter switch. Make sure you haven't accidentally switched it over to 2x mode.
    Oct 2015
    Yes, there is ! Thank you very much guys, this was the problem. I didn't know my shifter has such a feature. Does it have any use on a 3*n speed bike ?
    Quote Originally Posted by cpper View Post
    it is so you can switch to 2X, like if you replace the big ring with a bash guard.
  1. Problem with Shimano SLX front shifter 3spd
    By maxmckinnon in forum General Discussion
    Last Post: 01-17-2014, 05:31 PM
  2. Xt front der and shifter problem
    By larryarroyo in forum 29er Components
    Last Post: 05-24-2013, 11:22 AM
  3. XO Front Der Shifter Problem
    By K091254w in forum 29er Bikes
    Last Post: 06-10-2012, 07:27 PM
  4. Sram X0 front shifter problem
    By ts8169 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2012, 10:15 AM
  5. HELP with SCRAM X7 front shifter problem
    By edj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 08:27 PM
