Results 1 to 3 of 3
    First ride with M8000 1X11
    Converted my Turner Fluxís (2008) triple drivetrain to a 1X11. Went with Shimano XT M8000. Set up works great! Iím using Race Faceís narrow wide 34 tooth, I wanted to get some faster speed with the 11 tooth cog. I went with a 40X11, decided the closer spacing would shift smoother.
    I feel with a 26er, a 34 tooth is tolerable. Also helps to push myself more on the hills.
    On my maiden voyage, I set 10 PRís on Strava.
    Coming from a non-clutch derailleur, the Shadow+ has absolutely zero chain-slap. Itís new to not hear the chain, although I havenít had to worry about it with Lizard Skin wraps. Only thing is I feel the shifting takes a bit more effort.
    Bottom line, I feel this is a great upgrade. Total was ~$250.
    All I need is a magic link.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Nice classic Flux!
    I got some bad ideas in my head.
    Oct 2012
    I have the same 2008 turner flux tnt w the green color! I converted my santa cruz nickel to xt 1x11 and it shifts smoother than other 1x10 shimano xt systems I have had. Mess w the fine adjuster at the shifter some, I bet you will find the sweet spot. Might be derailleur hanger is bent? Chain to long? I think I will set up the flux w 1x10 extended cog and lose the 3x10 I have now. I love the way the flux climbs and it does just fine on the downhill even w the steeper head angle.
  1. Shimano announces XT 1x11 (M8000)
    By HSracer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2016, 03:23 PM
  2. XT M8000 1x11 and Surly Ogre dropouts
    By Ze_Zaskar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2015, 12:27 AM
  3. Just converted 3x10 to 1x11 (Shimano M8000)
    By sjhiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-01-2015, 12:07 AM
  4. Ext Range 1x10 vs OEM 1x11 (m8000)
    By minimusprime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2015, 02:14 PM
  5. Need chainline advice with my new 1x11 before I join the chain - M8000 XT and RF 30t
    By SB666 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2015, 06:20 AM
