Results 1 to 5 of 5
    Jul 2017
    Ever swap out a $45 BB with a $100 to find they both use the same bearings?
    Doh
    Well it was a different crank and spindle diameter too.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Not quite, but after being shipped $100 bb with dry bearings I open up all of them and check for grease.
    Aug 2017
    You can get $20 Shimano HTII BBs and there is nothing wrong with them.
    All it is is an interface to the frame to hold the bearings. Those bearings are not that expensive either.
    Not sure what the $45 BB was doing for you better than the $20 type, or what you expected from the $100 BB.
    The $100 BB may be 2 g lighter and will look a bit more shiny.
    2018 Motobecane Sturgis NX
    2016 Giant Toughroad SLR1
    Jul 2017
    The $45 BB came with the bike and the $100 is for a different spindle and is shiny. The bearing manufacturer and level were the same.
    You're right..the $20 would have been just fine.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    A cheap bearing properly maintained (regular clean, inspect and grease) I suspect will last longer than an expensive bearing that have been ignored and not maintained.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Can I swap XT FC-M760 with XTR FC-M970 cranks and use same 3 rings?
    By jtb33 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2017, 11:07 PM
  2. Do they hang low, do they wobble to and fro, do they light up?
    By dbhammercycle in forum Off Camber (off topic)
    Last Post: 05-15-2015, 10:06 PM
  3. Do SRAM mountain and road use the same cable pull? are they interchangeable?
    By MultiRider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-27-2014, 05:03 PM
  4. Replies: 21
    Last Post: 04-15-2013, 07:49 AM
Members who have read this thread: 111
