Results 1 to 3 of 3
    Nov 2015
    Etype bracket front dellaurier. Pls help
    Hi,
    My giant uses etype bracket for front dellaurier. Recently I removed dellaurier and I noticed that etype bracke has no stiff connection to bb. You can run bracket around. Is that the way it suppose to be? After bolting dellaurier to the bracket the whole thing still moves slightly. After cable attached it looks to be ok.
    So the main question is , should etype bracket be somehow stiffened to bb?
    JZ
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    It's held captive by the threaded bottom bracket. If it's freely rotating, the bottom bracket may have loosened. Re-torque the BB.
    Nov 2015
    Thank you. So in that case it is posibble that giant factory assembled my bike wrong way? It was first time ever I removed front dellaurier. I will disassemble this again to have another look.
  1. Can I use a Shimano XT M780 Etype 3x10 Front Derailleur in a 2x10 application?
    By Procter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-16-2014, 07:49 AM
  2. FD Etype M770 XT 3x9 if change to SLX M665 2x9 do I gain any tire clearance for 650b?
    By Grizzly900 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-21-2013, 08:58 AM
  3. Mudguard hole bracket for front fork?
    By empre in forum Beginner's Corner
    Last Post: 09-27-2012, 03:36 PM
  4. Hollowtech bottom bracket with E-Type front derailleur
    By pcmark in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2012, 09:34 AM
  5. Bottom bracket placement? Front or rear Triangle?
    By SuperSlow35th in forum Shocks and Suspension
    Last Post: 12-12-2011, 09:33 PM
