Dropped chain with Shadow?- Mtbr.com
Results 1 to 3 of 3
    mb_
    mb_ is offline
    Reputation: mb_'s Avatar
    I have a new ride with a new Shadow XT rear derailleur. On the triple crankset, shifting from middle to small ring is throwing the chain a lot - several times on first ride. I typically shift under light pedal pressure, and when I tried shifting with more pedal pressure, it seemed to work better. With Shadow switched off, it doesn't seem to be a problem either.
    Curious if anyone is having similar issues. Like I said, new bike so I have some tinkering to do. I'll check chain length, but it seems on the short side if anything.
    noob
    Reputation: trueblue01gt's Avatar
    look at your front deraileur. its probably not set up properly and shifting to far to the left and dropping off of granny gear.
    2007 Fisher Rig
    2011 Trek Paragon
    2013 Trek Madone 2.1
    Reputation: Betarad's Avatar
    Sounds like a limit screw adjustment on your front D is what's needed. I doubt it has anything to do with your rear D.
