Results 1 to 7 of 7
    Sep 2012
    di2 with x01-- long cage or short?
    I know i read somewhere on here that someone put a sram cassette with thier Di2... But darn if i can find who it was... Im pretty sure it will work fine..
    Question-- do i need to go long cage or do you think the med cage will work with a 2*11 di2 setup...
    Reputation: 006_007's Avatar
    pretty sure if you are going 2x you will need the greater gear capacity of the long cage. I have not searched on the shimnano site to get their gear calculator - I would do that and cross reference with your gearing you intend to use.
    I think you would be pushing it using either with you running 2x11. I don't think it would cope with the 10-42 cassette range and a double up front unless you were very careful what gears you were in.
    Quote Originally Posted by Rick Draper View Post
    thats the beauty of di2 - you program it so it cant go in those bad combos!
    Sep 2012
    plus... shimano just came out with a 11x42*11 and officially said it works with di2.. So id imagine with the right derailleur all should be happy... Plus what 006 said-- id just program it to never go big big or small small .. Plus id imagine di2 is allready programmed not to go bb or ss...
    Quote Originally Posted by SB Trails View Post
    The 11-42 is only quoted as working with 1x11 in the tech documents.
    Sep 2012
    Hmmm ill have to go back and read that again.... But even if so-- id actually think a 2x system would be even less stress on the drive train... For the reason that the system will jump to the smaller (left side) ring -- hence biasing the chain over vs a normal 1x system that the chain is pulled over to the extreme side....
  1. When to use a Long Cage vs Short Cage Derailleur?
    By Trentkc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 2 Weeks Ago, 08:23 AM
  2. When to use a Long Cage vs Short Cage Derailleur?
    Last Post: 01-04-2016, 02:03 PM
  3. What is the difference between SRAM RD long cage/short cage pulleys?
    By gibsonlespaulspecial in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 05:17 AM
  4. long cage or short cage deraileur for 1x10
    By ToneyRiver in forum All Mountain
    Last Post: 03-17-2014, 02:21 PM
  5. Short cage vs long cage-rear mech
    By Qcamel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2011, 02:55 PM
