Results 1 to 6 of 6
Thread: Crankset Help
    Dec 2015
    Crankset Help
    I'm building my first bike, and need some help. I want to setup either a 2x10 or 3x10 drivetrain. I'm looking for an inexpensive crankset to go with the following setup.
    Could I use Shimano Alivio M430, square taper, with this setup? If not, any recommendations? Would prefer not to spend more than $50, if possible.
    not really an mtbr member
    Reputation: theextremist04's Avatar
    Basically any crankset is compatible these days. The biggest issue is BB/frame/crank compatibility. For example, you can't run a square taper BB on a PF30 frame.
    Dec 2015
    Great to know. I'm starting with a 2012 Niner Air 9 frame, which looks like it has a PF30 bottom bracket. I'm not familiar with a Press-Fit BB. Essentially, I will need a PF30 bracket and compatible crankset? Is there anything else I need to be aware of?
    Reputation: watts888's Avatar
    Oct 2012
    For cheap, hard to beat a square taper cartridge bottom bracket and an alivo crankset. Heavy, but will last a long time. For a just little more money, I'd also look at something like this though. A little lighter, easy to adjust chainline.
    Race Face Ride Crankset OE > Components > Drivetrain > Cranksets | Jenson USA
    "a hundred travel books isn't worth one real trip"
    Quote Originally Posted by jlucas View Post
    I think you might have an issue with the setup you're thinking then. The PF30 adaptors don't have anything to hold them in the frame, so you need some sort of crankset that holds the sides together: external BB is the simplest answer. SLX is a great choice.
    Oct 2012
    completely missed the part about the frame being press fit. Best of luck with that. External bearing would be OK with the press fit adapters, but I'd stick with a true press-fit bottom bracket.
    SRAM PressFit 30 to BSA Adaptor Kit | Chain Reaction Cycles
    If you really do have a press fit bottom bracket, another option is seeing if you can get it threaded at your LBS and use the newer threaded bottom bracket standard. All the benefits of the pressfit 30 bottom bracket standard, without being pressfit.
    First Look: T47 Bottom Bracket Standard | Bicycling
    Industry launches new, larger threaded T47 bottom bracket standard ? say goodbye to PressFit!
  1. Converting an FSA triple Dynadrive Crankset to a double crankset
    By wheelinthai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2014, 06:20 AM
  2. SRAM S600 crankset or Shimano M410 Alivio crankset?
    By DanHS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2014, 12:05 PM
  3. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  4. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  5. Chainline difference in a 2x crankset vs a 3x crankset?
    By fire_strom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 06:50 PM
