    Reputation: dirtyjack's Avatar
    Converting XX crank to 1x
    I decided to switch my Tallboy to a 1x10 and converted my XX crank using a Blackspire Snaggletooth 30T ring and a Praxis 11-40 cassette. All in, it was less than $200 using the existing crank and derailleur. The XO type 2 derailleur shifts smoothly in the stand. I'll find out how well it works on the trail tomorrow.
    I took the chewed up outer ring to the grinding wheel and converted it into a bash guard. Not too shabby.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Te mortuo heres tibi sim?
    Nicely done, and cheap/easy way to do it!
    bike tester
    Reputation: syl3's Avatar
    excellent idea, i will use it to convert my Zesty to 1x10
    Turns out it took a few weeks and tweaks to get the shifting perfect. It was shifting ok for the first 8-10 rides, then it started sticking when dropping from the 28 to 24. I backed the B-tension off a bit and it's shifting better than ever.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
  1. Converting a 3 by SLX crank to a 1 by
    By Spencerespencer in forum 29er Components
    Last Post: 09-16-2015, 10:58 AM
  2. Converting Surly OD crank to Single?
    By canyonrat in forum Fat bikes
    Last Post: 03-25-2015, 02:32 PM
  3. converting a SLX m660 crank to 22/36
    By Oneronin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-25-2012, 10:07 AM
  4. Converting 3x9 to 2x9 on Square Tapered Crank
    By DanZo337 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2012, 11:56 AM
  5. Converting existing crank?
    By llckll in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2011, 02:22 PM
