Comparing Granny Gears- Mtbr.com
Results 1 to 10 of 10
    May 2012
    The granny gear on both these bikes is 1.5 ratio for the SRAM 2x10 and 1.4 ratio for the XCT 22/32/42, right? About a 7% difference, which is not much, right? Using the sheldon brown program Sheldon Brown's Bicycle Gear Calculator Thanks Bill
    Cranks SR Suntour XCT 22/32/42t
    F. Derailleur Shimano TX50 dual pull, Top swing, 34.9
    R. Derailleur SRAM X-4 8spd
    Shifter SRAM X-4 trigger 8spd
    Gear SRAM PG-820 8spd Cassette (11-32t)
    SRAM X7, 2x10 Speed
    Front Derailleur SRAM X7
    Rear Derailleur SRAM X9
    Cassette SRAM PG 1050 11x36, 10-Speed
    Chain SRAM PC 1051
    Crankset SRAM X7, 26/39
    Oct 2011
    Sounds like ~7% difference if your ratios are correct, not a huge difference, but you might feel it on a steep climb, probably about half a gear on the big end. For example between the 36 and 32 teeth cogs on the 11-36 cassette is a 12.5% jump.
    I'm more a fan of gear-inches myself that gear ratio, but you come out the same basic information in the end.
    Feb 2012
    Typically 8 speeds have ~ 13% change in ratios between gears.
    A 9 speed has ~12.5%, mainly just one more gear than 8 spd.
    A 10 speed has ~12.3% , again mainly just one more gear than 9 spd.
    So a 7% change is more or less 1/2 gear change, or, not much.
    My original setup had a granny gear 1.455 and 2nd gear of 1.182, a 19% change - a kind of large change. I swapped cartridges so the change from granny to the next gear is 13% and found the result an improvement.
    If you look at all the cassettes/crank combinations generally the change from gear to gear is around 13% so they must have discovered that's a useful ratio - significantly lower % is a worthless spliltting of hairs, significantly great % can be uncomfortable.
    May 2012
    Thanks, 7% is ok, maybe better.
    Can someone check my calculations with the program? I think I enter the numbers correctly?
    Bill
    Feb 2012
    Quote Originally Posted by Billinsd View Post
    Bill
    Looks like your calculation for the 8 speed granny is off. I got 1.3 for granny on the 3x8, which makes more sense.
    May 2012
    I checked again and got 1.5 for the 8 speed and 1.6 for the 10 speed. I am using 29 inch wheels also. Thanks Bill
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Is that ratio on 10-speed 26/39 front 11-36 rear the same as 9-speed 20/32 front 11-34 rear?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Feb 2012
    Quote Originally Posted by Zachariah View Post
    Nope, the 9 speed is quite a bit lower. My ratios are not the same as Sheldon's because his take into account crank length and tire circumferance which I don't. Anyway, by my basic calculations:
    10 speed granny = 1.385
    9 speed granny = 1.70
    The 26 tooth small gear on front must be for a 26" tire and a bit large at that, mine is 22/32/44 and the 20 tooth for the 9 speed is more likely for a 29" (I assume in so far as I don't have a 29"). It would be quite low for a 26", in fact too low because there comes a point where you have to maintain a fast cadence while creeping up a steep hill which for me is a formula for wiping out my legs real quick and not maintaining very good stability in the process, AKA a 1 mph "wipe-out."
    Why not? Somebody once told me if you are going to do something, you might as well do it right. Difference is usually only 10-20%.
    Feb 2012
    Quote Originally Posted by Yogii View Post
    Cuz I have only one bike, one crank, one brain cell working on this, (the other one's resting) and I know if I go to a smaller tire (e.g. 1.95) the ratio will be a bit higher, and my math was easier than his. It's all relative.
