Chainring replacement: lube chainring bolts?- Mtbr.com
Results 1 to 5 of 5
    Ski during the off-season
    Reputation: journey's Avatar
    I am replacing the inner & granny rings on my RF cranks. I cleaned up the chainring bolts as I put it all back together, but I did not lube the threads. Should I have?
    Quote Originally Posted by journey
    You should use grease, anti-seize, or thread locker on all threaded fasteners. (I would've used grease.)
    Ditto with the grease.
    I had not completely tightened all the chainring bolts or re-attached the crank to the BB yet, so I guess I will be doing this tonight before I put everything back together...
    Thx.
    ...idios...
    Reputation: SteveUK's Avatar
    I'll third that. I also apply a thin layer of grease on the outside of the peg barrels, where they touch the spider/rings.
    Steve
    Diogenes
