Results 1 to 5 of 5
    Chainline on xt 1 x 11
    Just installed a new xt 1 x 11 drivetrain (32, 11-42). Set up went pretty well, but I'm finding that I'm a getting a fair bit of grinding in the 40 and 42. The chain really does have to get dragged over to the centre of the bike - the line is quite "diagonal." I've double checked parts, spacers, set up etc., and I can't find any mistakes on my part. To be fair, I'm only running the drivetrain in the bike stand, and the grinding isn't too much worse than when I went 1x10 with a one up 42 on my old drivetrain, but it just digs at my inner OCD... Anybody experienced the same? Will it quieten down a bit with wear? Am I overlooking something? I almost feel like removing the drive side spacer on my BB to get the chain a bit more centred...
    Reputation: RS VR6's Avatar
    IIRC...the 11sp cassette is a bit wider than a 10sp. If your CL is already extreme with a 10sp...it'll be that much more with the 11sp.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Can you move your chainring inboard with spacers?
    I got some bad ideas in my head.
    I installed another BB I had lying around, and it improved things a bit in the 40. I'm going to see how things are after the chain gets worn in a bit. But otherwise, yes, I may try experimenting with spacers, either some thin washers on the chainring bolts, or maybe move the 2.5 mm spacer on my bb to the non drive side. I guess with 11 speeds on a traditional shell is pushing the limits a bit... thanks.
    Quote Originally Posted by Travis Bickle View Post
    Oct 2013
    Same issue here, and you seem to know pretty much what options you have. Pressfit BB on mine so no chance of playing with spacers there
    2019 Yeti SB100
    2016 Transition Smuggler
  1. HD3 X01 Chainline
    By ew505 in forum Ibis
    Last Post: 02-23-2016, 06:21 PM
  2. How'd I get this chainline? 1x7
    By Shavednslow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2014, 08:31 PM
  3. XX1 chainline
    By phatfreeheeler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-21-2014, 07:20 PM
  4. best chainline to use for 1 x 10
    By jrs67 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-21-2011, 03:40 PM
  5. 3mm too much off chainline
    By greasemonkeee in forum Singlespeed
    Last Post: 10-08-2011, 08:33 PM
