Results 1 to 3 of 3
    Mar 2011
    Chainline questions going from 3x9 to 1x11
    Hi all, I recently built up an On-One 456 EvoII with spare parts from my old xc bike. I want to upgrade to 1x11 and I have a few questions about chainline. I'm currently running old Shimano Deore XT with Truvativ Cranks using an ISIS drive 73mm bottom bracket without any spacers. The cranks are fine and I'd like to avoid buying new ones, so can I keep using these cranks if I upgrade to Shimano XT M8000? What about SRAM Gx with an 11-42 instead of their 10-42? What do I need to do to ensure that my chainline is correct?
    Edit: Looks like my chainline is 47.5mm on the middle ring and 54.5mm on the outside ring based on measurements I took myself with a tape measure.
    Feb 2015
    Hi,
    I would suggest using a N/W chainring the middle position of the crank. and fine tune the chainline using some of these.Chainline questions going from 3x9 to 1x11-id-outer-chainring-spacer-silver-55693.jpg
    Along with come longer bolts. The washers are available in varying thickness, so it's relatively easy to get the chainline spot on.
    Feb 2010
    Quote Originally Posted by abrooks View Post
    Hi,
    I would suggest using a N/W chainring the middle position of the crank. and fine tune the chainline using some of these.Click image for larger version.
    I had to do this on my bike. Was easy to do and once I installed them my shifting went from sketchy and nearly impossible to nearly perfect and reliable.
  1. How flexible is chainline with SRAM 1x11?
    By dstroud in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-08-2015, 05:25 PM
  2. 5010c 1x11 Chainline and BB Spacer
    By A.Christopher in forum Santa Cruz
    Last Post: 09-19-2015, 12:44 PM
  3. help with chainline on pivot Mach 6 1x11 setup
    By Pedro Rios in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2015, 12:28 AM
  4. Need chainline advice with my new 1x11 before I join the chain - M8000 XT and RF 30t
    By SB666 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2015, 06:20 AM
  5. Correct Chainline for HDR 1x11
    By DH_WP in forum Ibis
    Last Post: 05-07-2015, 07:59 AM
