Results 1 to 7 of 7
    Reputation: saruti's Avatar
    chain too long with 40\42 cassette
    hi guys
    been riding with 1\10 setup
    36teeth front N\W
    11-42 (oneup) cassette
    I find that for using this setup, I need the chain to bee long.
    whae its on the 40 \42 teet at the back, its OK.
    but when using higher gears, like the 11teeth, that bring the chain to bee too free, with not enough tension.
    the problem with this is when riding down the hill. when you use the smallest gear at the cassette.
    what leads sometimes to the chain bounc out off the front chainring. (even with upper guide)
    is there a solution for that?
    thanks
    Reputation: Junersun's Avatar
    Jun 2014
    And you can't take more links out? How about a chainguide? What RD are you using?
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    Feb 2015
    Unlink the chain, run it around the chainring and the 42T gear but not through the derailleur. See where the two ends overlap then add 1 inch (2 links). Break the chain there and relink. If you have a rear suspension, check how much chain growth you get through the full travel. You may need an extra inch of chain if you have a lot of chain growth through the travel.
    thanks
    but I know all this...
    still, I think its a big problem, especially if you go to 44T....
    Positively negative
    This doesn't sound like a matter of chain length but rather derailer length/capacity.
    Reputation: LyNx's Avatar
    BPN is correct, you are using the wrong length derailleur cage for the size rings and cassette you're using, simple as that. Assume it's either a Shimano GS or SRAM Mid cage, you should be running a long cage/SGS cage RD.
    Quote Originally Posted by big_papa_nuts View Post
    A mid cage should work just fine with his set up. Focus on chain length.
  1. Replaced chain, cranks, cassette and chain started skipping again!
    By red913 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2015, 08:38 PM
  2. New chain and cassette and still chain skips under hard pedaling.
    Last Post: 02-28-2015, 09:46 AM
  3. Chain/Cassette Wear After Chain Stretch
    By biggrumble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2012, 12:21 PM
  4. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  5. Newb: need advice on replacements for chain rings, cassette and chain
    By Porschefan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2011, 01:53 PM
