cassette cog drop alternative with 40T- Mtbr.com
Results 1 to 6 of 6
    Was just having an idle thought about the 40 or 42T cogs and the cog removal from the cassette.
    If you got a larger lockring (like for a 12T) could you just drop the 11? I mean dropping the 17 is a huge gap in the middle of the cassette.
    Reputation: broccoli rob's Avatar
    I think this will only work with certain set ups. I have a Wolftooth 40T, xt cassette, and DT swiss 350 hub. I tried removing the 11 and all of the cogs wouldn't fit over the splines. The only way I could fit the cogs over the splines was by removing the 17t and spacer. I think people using other 40/42t cogs are having better luck with this set up, maybe the WT is a little thicker or maybe it's my set up but that has been my experience.
    Thats quite odd, as the physical distance between cogs should be identical. Are you sure all of your other cogs were properly seated, nothing hanging up on burrs or similar.
    I tried it a couple of times and the 13t just wouldn't quite catch. I think if the 13t was a first position cog it may work. From what I have read in other threads people are having success without the 11t but not sure what kind of set ups. I was hoping this would work for me but its just not happening. I am getting used to not having the 17t though. BTW absolute black makes a 13t lockring but a 12 should work too.
    If you want to mod an 11-36 cassette to add a 40 or 43 giant cog, you can use an SLX or XT cassette and remove the 17 and 19 and replace them with an 18 tooth cog. I did that and it works very well. 11-40 with a 34 front.
  1. Drop-bar commute bike with wide range mtb rear cassette drivetrain Q's
    By Harold in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2014, 04:09 PM
  2. Alternative to the 12-36 HG61 9 speed cassette
    By Bike Whisperer in forum 29er Components
    Last Post: 01-22-2014, 05:49 PM
  3. Alternative to 1x11; 42T cassette sprocket
    By nightofthefleming in forum All Mountain
    Last Post: 12-01-2013, 10:01 AM
  4. Chain drop drop off and misalignment a norm?
    By boardrider02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2012, 01:20 PM
  5. Where are the alternative route that drop into Caballero Canyon?
    By robncircus in forum California - Socal
    Last Post: 08-23-2011, 10:03 AM
