Results 1 to 26 of 26
    Aug 2005
    Can't Get Rid of Play in RF Next Cranks
    I've got about one season on a pair of RF Next carbon cranks. They've been rock solid other than that stupid preload ring that I replaced with a beefier Cane Creek version.
    I noticed some wiggle in the non drive side arm so I took it all apart, cleaned it, re-greased it and reinstalled it and there is still a little wiggle in the non drive arm. I know the installation process is right and I know the drive side arm requires a lot of torque so its on there as tight as I can reasonably get it.
    I'm hoping for some insight on getting these cranks wiggle free.
    Vermonter - bikes, beers and skis.
    Bad bottom bracket bearing(s)?
    Never trust a fart
    Reputation: frdfandc's Avatar
    Sounds like play in the bearing
    Sent from my SM-G930V using Tapatalk
    Reputation: jazzanova's Avatar
    Make sure the spindle interface of the crank arm isn't disbonding.
    Has happened to many, including me.
    Well known next sl problem, disbonding pedal insert of the crank arm as well...
    Sent from my SM-G920P using Tapatalk
    Reputation: bridgestone14's Avatar
    Mar 2005
    can you tighten up the pre loader?
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by jazzanova View Post
    this was my first thought.
    I don't want carbon cranks...but if I ever did, they wouldn't be Race Face. The Turbine CINCH cranks are pretty solid, though.
    Aug 2005
    Ah bad BB bearing - good call. Makes sense. I値l also keep an eye on the spindle, I致e seen pics of those fail before.
    Thanks guys.
    Quote Originally Posted by VTSession View Post
    Thanks guys.
    Funny thing, I have just discovered my 2nd next sl is done. Didn't last a year. Just like the 1st one. And I am only 140lbs...
    Aug 2005
    Damn. So you're on your second pair? What keeps failing?
    You'd think these cranks would be more durable at the price they're charging. Might be time to go back to good ol' alloy Turbine cranks.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    This would be my guess too. Happened to my replacement after the first had a loose pedal insert.
    Second one had the crank insert get loose.
    3rd one is ok so far. Crossed fingers
    Quote Originally Posted by Shark View Post
    Do you know if there is a new warranty applied to the replacements?
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    No, I don't believe so. I had 2 sets of Next SLs and I lost track of how many times they were replaced. At one time they replaced with G4s which were no better. The last time they replaced with Next Rs which have been holding up fine since winter.
    I got some bad ideas in my head.
    Quote Originally Posted by Travis Bickle View Post
    Hard to find any solid info about the warranty on their website. Is it 3 years for next sl? Non g4.
    Anytime. Anywhere.
    I understand 3 years for all carbon cranks.
    Dec 2005
    I believe the G4 are finally being replaced by a new model. Asked my frame builder to get a price for some and was told that QBP has them clearanced/discontinued. Maybe G5 coming?
    Feb 2006
    I thought when they first came out they were longer warranty than 3 years, but I think it was removed from the website as I can't find anything about it anymore.
    Frustrating for sure.
    Aug 2005
    Well upon closer inspection, it is the spindle that has developed play where it connects to the non drive crank. I got these from a shop 2 states away over a year ago and have zero receipt so it looks like I知 S.O.L.
    I知 frankly kinda pissed. I致e been religiously using Race Face parts for over 20 years and when I invest in their high end cranks they fail after a season and I知 a stuck with them. Absolute crap product.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I had one like that and it was only loose, tightening the crank to the spindle (non-drive) solved it.
    Aug 2005
    Yeah I tried that after watching a video on how to remove the spindle. At least I was able to narrow down the issue to the left arm. I値l call RF and see if they can send me just a left arm.
    Time to cannibalize another bike to get some functioning cranks. P.I.A.
    Aug 2005
    So I contact RF and they said I'm basically S.O.L. because I don't have a receipt. That's their policy, it is what it is. I'm hoping a shop can order me just a replacement left arm.
    Worst case, I was thinking of using epoxy to permanently bond the left arm to the spindle. I'll never have a reason to remove the left arm. Anyone see this as a terrible idea?
    An epoxy that is actually strong enough and doesn't crack due to the loads imposed on cranks/spindles? I doubt it'll work in the long term.
    Aug 2010
    Attached Thumbnails Attached Thumbnails Can't Get Rid of Play in RF Next Cranks-next-sl-cranks.jpg
    Aug 2005
    Yeah I am rethinking the epoxy idea. I may try a Loctite type material that is meant for press fit bearings to see if that cures it. Otherwise, RF confirmed that I can order just a left arm from my local shop. Not ideal, but at least I'll get them going again. I'm dreading what RF will charge me for one arm.
    Quote Originally Posted by jabrabu View Post
    This picture frightens me. Were these destroyed for warranty purposes or am I in for a crank snapping episode if I keep riding them?
    Feb 2006
    They ask you to cut them when they are replaced for warranty. My first set had to be sent back.
    Oct 2015
    Been on a Raceface Cinch SixC downhill cf crank for several years that I bought used and no problem, just fyi fwiw.
    Oct 2015
    not sure if this may be what you need:
    http://www.pinkbike.com/buysell/2442271/
  1. Help! Can't get rid of play with SRAM GXP crank/BB
    By dantheman762 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2016, 04:09 AM
  2. Fly Ti 29er creaking - can't get rid of
    By isleblue65 in forum Motobecane
    Last Post: 10-11-2011, 11:19 PM
  3. Replies: 3
    Last Post: 06-23-2008, 12:59 PM
  4. Replies: 1
    Last Post: 03-10-2005, 12:51 PM
  5. how to get rid of my next race face right crank arm.
    By chirider990 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-26-2005, 12:13 AM
Members who have read this thread: 104
