Can I run a 11-42T 10 speed cassette?- Mtbr.com
Results 1 to 21 of 21
    Reputation: Sickmak90's Avatar
    May 2012
    I have a 2015 Breezer repack expert and I have swapped it over to a 1x. Iíve added a 30T front ring and I am debating on running a 11-42T 10 speed cassette or spending $300 for a XT 11-46 11 speed.
    My bike is basically like new still so I almost hate to remove a perfectly good 10 speed XT setup. Iíve heard that you can run a long screw and it might work?
    I think Iíd be happy with a 42T rear and it would be substantially cheaper than going 11 speed.
    Edit:: Now that I have a 11 speed derailleur coming should I go with a 46T cassette?
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    A friend rode that setup for a time, only problem was that the shifting was not as smooth, in alternative if your are not pleased with the shifting performance, you can just get a RD-M7000-10, it's a 10 speed derailleur with capacity to clear a 43 tooth cog.
    May 2012
    Well Iím gonna give it a try. I ordered a cassette and B screw from Jenson. I also grabbed a brake bleed kit and some oil, all for $63. Hopefully it works.
    Iím used to SRAM x5/7 and lowerish end derailleurs anyways, so Iím not used to buttery smooth shifting.
    Feb 2018
    You might want to consider https://www.wolftoothcomponents.com/products/goatlink
    This is what I did--XT 10 speed, 11- 42 Sunrace cassette+goatlink. Works great. Didn't need a longer b-screw.
    Reputation: Heist30's Avatar
    Apr 2018
    Yea, Goat Link is the way to go... Iím debating whether or not to try the Sunrace 11-46 10sp...
    May 2012
    I went ahead and got a goat link off amazon.
    Reputation: thasingletrackmastah's Avatar
    I use the 10-speed Shimano 11-42 cassette on a XT 10-speed derailleur (med cage). Works with the B-screw all the way in. (Although the 11-36 cassette shifted smoother)
    Id pass on the goat links. You can do it right for a marginal amount of money. Id go straight to using the correct derailleur.
    Shimano makes an 10 speed 11-42 and its excellent quality, just heavy (deore level). The 11s derailleurs are cheap and work perfectly with 10s. The new deore level rear derailleur has a clutch is specifically designed to work with the 42t cassette. Ive found the SLX 11 speed rear d to be basically the same price as the 10s clutched deore, and they're functionally identical and cross compatible.
    I went with the deore 10s cassette, 11s SLX rear derailleur, and a zee shifter for my kids bike. Its excellent and very smooth. Blows 9spd XTR out of the water by a mile. Super cheap setup, but its damn good.
    damned rocks...
    Dec 2014
    Quote Originally Posted by One Pivot View Post
    Id pass on the goat links. You can do it right for a marginal amount of money. Id go straight to using the correct derailleur (...)
    I agree with this, and just to mention that Shimano has a SLX M7000 10s rear derailleur.
    Link: https://bike.shimano.com/en-EU/produ...00-10-SGS.html
    May 2012
    Well I already got the goat link and the HG500 is on its way. Iím gonna give it a try and if it breaks or doesnít function well I will upgrade to a new derailleur.
    I got the goat link from amazon so I could return it but I bet trying to return the cassette to Jenson would be a Pita.
    If Iím gonna get a new derailleur I might as well just spring for the SLX 11 speed kit from eBay for $182.
    May 2012
    https://www.jensonusa.com/Shimano-SL...ear-Derailleur
    So this will work with the 42T 10 speed setup?
    Reputation: Velodonata's Avatar
    May 2018
    Quote Originally Posted by Sickmak90 View Post
    Yes, quite well.
    Reputation: Arebee's Avatar
    Sep 2012
    Quote Originally Posted by thasingletrackmastah View Post
    Same here. B screw cranked all the way in and works just fine.
    AreBee
    May 2012
    If the B screw or goat link works what is the worst that happens? I donít ride that often so I canít imagine wear being an issue.
    Cranking the b screw or using a goatlink works, its just clunky. Wear wont be an issue, it just works worse than stock, whereas using an 11s derailleur is butter smooth, better than 10s was.
    Reputation: Aresab's Avatar
    I used a goat link my first year with the bike and agree, clunky but works. The M6000/M7000/M8000 are silky smooth on 10 or 11 speed on our Repack. If you already bought the goat link, give it a try. The Shimano cassette seems good too although my family bikes have run the Sunrace models which are a bit lighter.
    May 2012
    My last bike had a Sram x7 rear and it was way smoother than the XT I have now. Iíve been putting off tuning it because I know Iím about to change some stuff.
    I really tempted to just try to sell all the 10 speed stuff for a few bucks and get the SLX 11 speed kit off eBay.
    May 2012
    Well apparently I just won a SLX m7000 11s derailleur on eBay sooo I guess Iím gonna try that.
    Since I had a 3x front with a giant ring I shouldnít need a new chain should I?
    Oct 2013
    It will work like a champ - https://youtu.be/1I4WzYbOb4M
    You might have to cut the chain to length though - https://youtu.be/cGjW-JJ40DQ
    2019 Yeti SB100
    2016 Transition Smuggler
    Pick up a new M7000 or m8000 rear Deraileur and throw the old one in you spare parts bag. You'll be glad you did.
    May 2012
  1. 11-40T or 11-42T as a replacement for 11-36T?
    By drabina in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2018, 12:49 PM
  2. 11-42 10 speed to 11-46 11 speed.
    By richwolf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2017, 03:53 PM
  3. 11-42 xt 11 speed cassette with old 10 speed shadow plus derailleur
    By 305coco in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2016, 02:11 PM
  4. Praxis 10 sd cassette or add One Up 42t to exisitnf cassette for 1x10?
    By DTL in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2015, 09:22 AM
  5. 11:11:11 on 11/11/11 and you were where?
    By giantbikeboy in forum Riding Passion
    Last Post: 11-17-2011, 05:41 PM
Members who have read this thread: 72
