    Sep 2012
    better 2x cranks to use with di2 then xtr?
    Building up a new bike.. Putting di2 on there and got to thinking if there would be a better/lighter/stronger crank to use vs xtr...
    Anyone know of a different crank set that would work well with the di2 system that might be worth looking at over xtr ? It will be 2x system...
    Pivoteer
    Reputation: tiSS'er's Avatar
    Quote Originally Posted by SB Trails View Post
    I'm using Race Face Next SLs, but in my opinion Shimano chainrings shift better.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: J.B. Weld's Avatar
    ^agree about the chainrings, there are lighter (better?) cranks but I think you'd get the most out of the d12 auto front shift with the xtr rings.
    The Specialized Carbon S-works cranks are not only one of the lightest options available, they are fairly cheap as well although you have to order them through a Spesh dealer. They use a standard 64/104 bolt pattern so you can run any old school chainrings on them. I currently use a set with an XTR 2*11 drivetrain.
    I might be off on my numbers, but I think with chainrings overall they were 100+ grams lighter than XTR "trail" cranks.
  1. Replies: 12
    Last Post: 07-14-2015, 01:27 AM
  2. X01 cranks OEM [Alloy] Vs X01 cranks aftermarket [Carbon]
    By jeffgre_6163 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2014, 11:29 PM
  3. SRAM x9 cranks vs x0 cranks...anyone have an accurate damn weight for both!
    By y0bailey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-23-2014, 12:48 AM
  4. Replies: 2
    Last Post: 05-06-2013, 12:38 PM
  5. Shimano M737 cranks vs M950 cranks!
    By cyberbackpacker in forum Singlespeed
    Last Post: 12-15-2011, 12:23 PM
