BB92 Press fit BB: How much "press"ure?- Mtbr.com
Results 1 to 5 of 5
    Uncle
    Reputation: Entrenador's Avatar
    I just received my new BB92 spec frame and matching Shimano BB. After reading the brief instructions, I "pressed" the BB into the BB shell. I'm a bit perplexed because the bottom bracket went in perhaps too easily(?) - I was able to get them 90% in 2-3 seconds, using my bare hands. I used my headset press (similar to the one below - no wing nuts) to push it in gently the rest of the way, and it didn't require any wrenches; I just turned the headset press nuts with my with my hands like I was wringing out a washcloth, and it seated all the way. Is this right? I was expecting it to require at least a bit of torque to get them in. This is my first go with a Press-Fit BB, so I'm unfamiliar with their tolerances, but I'm certain I've never seated a headset this easily - have always needed wrenches on the press.
    Mine has bigger nuts (that's what she said), but basically the same. What do you experienced techies think?
    thx
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    Depends on the frame. Some are looser/tighter than others (that's what he said).
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Uncle
    So checking the fitment of the cranks on the frame, I slid in the drive side crank arm spindle into the bearings and seated them. What do you know, when I pulled the crank to pop it out of the bearings, the drive side BB shell & sleeve came off with the cranks.
    Andrea138, thanks for the reply. Seems to be on the loose side to me, but again - first time. Anyone else thinking this?
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I haven't played with them myself yet but have been doing some research, though not much in the install area yet but I believe I read somewhere it's dependent on the frame manufacture..? not positive on that though but might be worth a look on their website.?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Oct 2007
    here's the park's thread on it.. seems they just go until they are flush..
    Park Tool Co. ParkTool Blog BB90 (BB86, BB92, etc) Bottom Bracket Service
