Anyone running a direct mount chainring on a SRAM 1400 crank?- Mtbr.com
Results 1 to 6 of 6
    Reputation: davesupra's Avatar
    Sep 2013
    If so, how is the chainline? What chainring are you using?
    Thanks,
    DaveH
    '20 Salsa Spearfish
    '13 9:ZERO:7
    '13 Trek Domane
    '16 Salsa Fargo
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    I have a race face direct gxp narrow/wide in 32t. Chainline seems pretty good, though I haven't measured it. What specifically do you want to know?
    Sep 2013
    I was curious if the chainline with a direct mount is different than using a std chainring and the spider. If it's different, is it more inboard or outboard?
    Thanks,
    DaveH
    '20 Salsa Spearfish
    '13 9:ZERO:7
    '13 Trek Domane
    '16 Salsa Fargo
    Land of the 230+
    Sep 2013
    Quote Originally Posted by davesupra View Post
    Thanks,
    If the chainline is different at all, it is very slight. Within a mm or two, I would think. When using a spider, the chainring sits just inboard of the location where the spider mounts to the crank. When using a direct mount chainring, there is some "dish" machined into the sprocket to make up for the offset, putting the teeth in a similar, if not exact position.
    Sep 2013
    Quote Originally Posted by GuitsBoy View Post
    Ok great. Thx for the info.
    DaveH
    '20 Salsa Spearfish
    '13 9:ZERO:7
    '13 Trek Domane
    '16 Salsa Fargo
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Any idea when the SRAM X-Sync direct mount 28T GXP chainring will be available? I've got the X1 1400 also, with 30T & spider. On the SRAM site it says 26, 28, 36, 38 DM chainrings would be available April 2015. No sign of them yet though on all the big sites (Comp Cyclist, Jenson, etc).
    Santa Cruz Tallboy 4
  1. Replies: 6
    Last Post: 01-18-2015, 06:15 PM
  2. SRAM Direct Mount Spiderless Narrow/Wide Chainring Options - BB30 Design
    By tiflow_21 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2014, 10:56 AM
  3. SRAM x1 1400 crank with 28 tooth ring?
    By cburdick1 in forum 29er Components
    Last Post: 11-25-2014, 11:36 AM
  4. Replies: 2
    Last Post: 11-06-2014, 12:05 PM
  5. Technical question- SRAM xo crank with wolf tooth direct mount
    By LewisQC in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2014, 05:56 PM
