Another BB sizing question- Mtbr.com
Results 1 to 2 of 2
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    Went and bought some gear for my NRS build the other. (come on Australia Post where is my bike??)
    My LBS (not a Giant dealer but a bl00dy good mechanic) was not sure what size BB I needed but said that most of the FS'ers that he had seen lately were a 73mm BB shell size.Was playing around on MTBR today (as you do). Did a search on NRS BB size and realized that it said that the correct size is 68mm. Rang the LBS and explained this to him but I think that he thought that I meant that I had bought a 68mm and needed a 73mm as he said that he had spacers that would fix the problem.
    My question is this. Is there a way to make a 73mm BB fit a 68mm shell or has my LBS misuderstood. If there is can someone please explain as I cannot see how it would work. I can see how a smaller BB could be made to fit into a larger shell but not the other way around.
    Cheers
    TR
    Derailleurless
    2.5mm spacer...
    He'll put a 2.5m spacer under the drive-side flange. Essentially, on both sides of the shell you'll have 2.5mm of threads that aren't engaged in the frame.
    I'd really prefer to have the correct size in there. It's a high stress area of the bike, and the more engagement the better. Is mine a valid concern? Probably not. Many BB's are designed to be installed in exactly the same manner your mechanic is installing yours. Your call!
  1. Question - How do I change or edit?
    By mtbbrian in forum Riding Passion
    Last Post: 02-17-2004, 02:03 PM
  2. NRS sizing question
    By sp00kme in forum Giant
    Last Post: 02-02-2004, 08:34 PM
  3. Component SPEC Sizing for Blur?
    By SCHUMACHER in forum Santa Cruz
    Last Post: 01-16-2004, 12:06 AM
  4. switcblade question
    By pintense in forum Titus
    Last Post: 01-15-2004, 06:22 PM
  5. Xpost from "Shocks"...Monster T Question.
    By badfish in forum Downhill - Freeride
    Last Post: 01-14-2004, 03:34 PM
