Results 1 to 8 of 8
    Jul 2013
    28 tooth Chainring for an Eagle GX
    Please recommend a 28 tooth chainring for an Eagle GX 12 speed. You guys are the greatest, thanks!
    Never trust a fart
    Reputation: frdfandc's Avatar
    Eagle 28t chainring from SRAM. There ya go. Recommendation.
    Oct 2017
    SRAM chainrings are good, you can try a different offset to see if it might help your chainline at the same time.
    or you can try a oval chainring offered by Absolute Black, Wolftooth, Oneup etc
    Jan 2017
    any narrow-wide in the correct offset would be fine. I have used raceface and absoluteblack.
    Could also try a 30t oval.
    Nov 2017
    Quote Originally Posted by frdfandc View Post
    I thought SRAM only made Eagle chainrings from 30 - 38t. I know that AB goes down to 28t and explicitly states that it works with Eagle, but I suspect that's true of the other manufacturers as well.
    Oct 2017
    I think the chainring doesn't have to be Eagle specific but maybe 28T is special. I use a 32T Non-Eagle chainring with my GX/X01 Eagle drivetrain just fine.
    Never trust a fart
    Quote Originally Posted by wayold View Post
    You may be right.Wolf Tooth makes a 28t I think.
    Jul 2013
    Thanks for all the replies! Looks like I can get a Wolf tooth 3 mm offset on Amazon for $66. Im thinking I will probably will go with that unless something better pops up?
  1. Wolf Tooth GCX 46 Tooth Cog
    By DrDon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2017, 10:28 PM
  2. SRAM Eagle chain with xx1 (non-eagle) chainring.
    By LyncStar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2017, 05:19 AM
  3. 36 tooth to 32 tooth sprocket
    By mcbike420 in forum Downhill - Freeride
    Last Post: 10-19-2015, 07:54 PM
  4. Replies: 0
    Last Post: 05-29-2014, 10:54 AM
  5. Shredded 11 tooth cog, broken teeth on both 15 and 17 tooth cogs
    By tgmoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 09:43 PM
Members who have read this thread: 43
