2018 Shimano XTR 12-speed - Page 8- Mtbr.com
Page 8 of 8 FirstFirst ... 45678
Results 1,401 to 1,523 of 1523
  1. #1401
    Reputation: Velodonata's Avatar
    May 2018
    Quote Originally Posted by Harold View Post
    It's not hard at all. I'd say it's paper thickness at most. Probably thinner. I put my calipers on it and looks to be 0.15mm thick.
    Cool, thanks. I followed up with my supplier and I just got word they did finally get some and are going to send me a couple. I am getting maybe a hint of noise with only a few rides on it, so it certainly won't hurt to have it in there.
  2. #1402
    Apr 2018
    Quote Originally Posted by Velodonata View Post
    How thick and what is the hardness of that shim anyway? I still haven't got my hands on one, the place I bought my cassette from was supposed to track one down for me but that hasn't happened, and I haven't gotten around to it otherwise.
    semi-soft? feels like a lexan
  3. #1403
    May 2015
    So I have XT 12 on older Bronson, non-boost, 2015. Sram 1400 gxp cranks (64/104). Right now it's running with a raceface 30t n/w chainring. Sram quicklink, a little noisy but I'm okay with it.
    Developed some knee pain after testing out a new Ibis Ripley all weekend and then went back to my bike. Don't know the cause (could be the Ripley, which only manifested after I got back on my bike, could be I rode a lot that weekend more than normal).
    Anyway, severe knee pain after 6 miles now. Took two weeks off, still had pain. So I'm looking to ease it up a little. I hear Ovals might help. Also maybe easier gears for now.
    My choices are limited because of the 104bcd. I can choose:
    1 - WT shimano 12 speed compatible 32t oval, or
    2 - AB oval Non-Shimano 12sp, 30t.
    anyone using the AB non-12sp specific with no problems?
    EDIT: I guess AB now has a 104bcd shimano 12sp Oval. I didn't see that a month ago, somehow I missed it.
    So now it's 32 12sp specific, or 30t 12sp specific from AB.
    Does the 32t oval feel similar to a round 30t? I mean, I'm rarely in my 51t I just need to use it more instead of trying to power through it (possibly causing my knee pain).
  4. #1404
    May 2015
    Quote Originally Posted by Nurse Ben View Post
    So you have a Microspline driver designed for your hub? I don't understand why it would need to be modified, it's a driver, so if it fits the hub then it will work in any frame that has the correct hub spacing.
    If you can't spin the cassette with the axle tight, look at whether the cassette is clearing the spokes; you may need a cassette spacer. Spacers are common, they come in all thicknesses, get the thinnest that'll allow the freewheel to spin freely, Hope, I9, and Onyx require spacers in some instances depending on cassette and wheel build.
    It was discussed in previous pages. But the new DT Swiss microspline adapter doesn't work with older DT swiss hubs. I have an old Roval carbon set, which apparently also uses the old dt swiss hubs. There is a slight flange that rubs with the hub.
    My buddy works at some cnc/milling whatever factory. He smoothed it out for me. All good now.
  5. #1405
    Jan 2016
    Quote Originally Posted by jdang307 View Post
    Knee pain might be from saddle improper height.
    Also too much forward or backward.
    Maybe the other bike created it and a few days of will let it disappear.
  6. #1406
    since 4/10/2009
    Reputation: Harold's Avatar
    Step 1: Rest until no pain
    Step 2: If pain persists after resting, see doctor.
    Step 3: I fail to see how drivetrain is a factor here.
  7. #1407
    Reputation: PuddleDuck's Avatar
    Quote Originally Posted by 33red View Post
    This. Sudden onset knee pain from riding a different bike sounds like the bike really didn't fit you well and caused an issue, or exacerbated an issue that was just under the radar.
    As background, the Ripley has a VERY steep seat tube angle that positions you way forwards relative to your Bronson..this places A LOT more load on your quads...which can be a recipe for knee pain.
    You tell us that you have "sever knee pain". That's your body saying that it's really unhappy. I'd listen to it, and go and see a physical therapist to
    - understand what's going on and what's causing your pain, the root cause of the issue.
    - how to treat the cause of your pain e.g. strengthen certain muscles
    - get some massage done on areas that might be too tight
  8. #1408
    May 2015
    yes I am aware it may be all of that. That's why I said it might be the ripley, or fit (though I've ridden fine on the Brony for 4 years), or over use.
    But I also tend to use one gear harder than is comfy in an effort to replace my squats at the gym since I have been riding more than working out. So I'll mash the pedals and my leg movements become more up and down than round and round. Both of those may also contribute to knee pain.
    I took 2 weeks off and first time back on the saddle, it returned after 6-7 miles. I have no pain walking around after. Or jumping, or air squatting. Just pedaling on my bronson, which I rode fine for 4 years with no issues.
    I realize it can be ANY of that. Bike fit on the Bronson just doesn't sound like it should be an issue because ... well I've ridden the Bronson since 2015. I've ridden tons of other bikes that don't fit me right, including an SB100, Intense Tracer, Yeti SB130 that were too large for me (my friends' bikes) for much longer rides.
    So it could be any of it. So I'm in the process of elimination, and wanting to keep my gearing easier so if it is indeed me mashing on the pedals uphill I want to have easier gears just in case. We do around 20k elevation a month. Indeed, the last couple times, lowering it to the easiest gear eased the pain.
    So if the AB oval that is not designed for Shimano 12sp works just fine, I'd rather get that so the easiest gear is easier than on the HG+ compatible AB oval.
    Reading back, it seems others have not had an issue so I may go with that unless someone has another opinion? I wish AB made a 30t oval that is HG+ compatible.
  9. #1409
    Jan 2016
    Up north(quebec) about 4-5 years ago many bought a Norco fatbike 18 speeds. To fit a wider tire they went 1 ring. To climb they went Oval. It is a bandaid for a poor transmission with not enough range. A 12 S Oval is not needed.
  10. #1410
    Jan 2016
    I just tought, if 2 weeks did not help, it might be new shoes?
    new pedals?
    cleat moved?
    new crank arms lenght?
  11. #1411
    Apr 2015
    Oneup told me quite some time ago that it'll be awhile before they have HG+ compatible rings. Are you certain that it's not just the quick link that is the problem everyone else has?
    I've been exchanging emails with OneUp. The latest update said the Shimano HG+ 12-speed compatible Switch chainrings will be ready for sale right around the first week of November.
  12. #1412
    Jan 2009
    Quick question guys when setting up the b tension with the marking on the rear mech are you setting it up with shock fully deflated or not bothering and just doing it as normal air pressure in??? On a full suss bike of course
  13. #1413
    Reputation: tom tom's Avatar
    Quote Originally Posted by Didzy2009 View Post
    Complete instructions are at the link below..........
    http://si.shimano.com/pdfs/dm/DM-MARD001-00-ENG.pdf
    I Pity The Fool That Can't Ride A Bike Without A Dropper!!
  14. #1414
    Jan 2009
    Quote Originally Posted by tom tom View Post
    Cheers but it doesn't even mention anything other than setting it up to align the marker.. Doesn't state whether that's stationary or whether full suss or not!? Unless I'm being blind
  15. #1415
    Jul 2019
    It would not hurt to do it like Scram GX and set it with rider sag. It only change 1 mm so its not a huge difference between sag and non sag.
    I like setting B screw to where it shifts the best at its lowest possible setting.
  16. #1416
    Rocks belong
    It states that chain length is different for full suspension and hardtails and guides you to ensure you have enough chain length for your frame's chain growth.
    I followed their instructions "to a T" and it works admirably on my F/S frame. (B-screw was set static, bike on the stand)
    2018 Shimano XTR 12-speed-capture-1.jpg2018 Shimano XTR 12-speed-capture2.jpg
    I like 'em long, low, slack and playful
  17. #1417
    방랑외국인
    Reputation: motard5's Avatar
    Quote Originally Posted by Dave Mac View Post
    thats fantastic thanks much, what going on witht chain specks slx cheaper and lighter??? what am I missing??
    Sorry, looks like a mis-type:
    SLX CN-M7100, 252g, $31,99 usd
    XT CN-8100, 252g, $43,99 usd
    XTR CN-9100, 242g, $64,99 usd
  18. #1418
    May 2016
    Today I managed to brake lower part of outer cage on my rd-m9100 sgs (under the bolt). Derailleur is still working normally. It looks itís just ďbeautyĒ failure, only lower part of lower pulley (and therefore chain on that place) is not covered or protected from outer side.
    Do you think is worth replacing outer cage? Will outer cage from xt work normally or itís better to invest in new xtr one? AFAIK only difference is materiel used, or?
  19. #1419
    Oct 2013
    Take a look here at the differences between the XT and XTR - https://youtu.be/ovNCyKGKMvk
    2019 Yeti SB100
    2016 Transition Smuggler
  20. #1420
    May 2016
    Hereís a photo:
    Worth changing it?
    If yes, Iíll probably buy xt and just take outer cage from it and replaced it on xtr. Cheaper than xtr outer cage + more spare parts
  21. #1421
    May 2018
    Quote Originally Posted by Matija899 View Post
    Worth changing it?
    I would just clean up the rough edges with a Dremel and ride on. As long as the damage doesn't get any closer to the pulley bolt than it appears in the picture and the derailleur is performing normally you are good. I would consider removing the part that now forms a hook, if you are in an area where there is loose vegetation and stuff that it might grab. I think it would fill up with moss fairly quick here. If there are any other reasons you need to fix it, you will know soon enough.
    Edit- OK I did miss one obvious issue, I should have had my coffee before replying, and you may be well aware of this, but the chain is not going to be retained on the jockey. Which could lead to a serious drivetrain kerfluffle. So yeah, I would buy another derailleur and consider this one spare parts for future damage. Or fix the cage, which is possible but not worth getting into working with carbon just for one component.
  22. #1422
    Reputation: OneTrustMan's Avatar
    Nov 2017
    Any long term experience on if the new splined hub also get those notches from the cassette?
  23. #1423
    Oct 2013
    Check it out here - https://youtu.be/GbdhqXtVlMQ
    2019 Yeti SB100
  24. #1424
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by mevnet View Post
    1:55 and 3:15 shows scoring on the microspline, but it's difficult to say how bad. Hard to imagine why shimano is still doing loose cogs down low, especially 4 on XTR and 5 on XT.
    Still, hard to say how bad this is in the video, maybe not really bad. He only used it for 2 months though. I reckon in a month or two we should start to have a lot of users that have used it for approximately a year or so. Then the data should start to get a lot more reliable and indicative of whether there's a continuing issue or not.
  25. #1425
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Check the last photo on the article to see some gouging on the micro splines. It's not much but I would prefer that they were not there at all.
    https://singletrackworld.com/2019/06...-frustrations/
  26. #1426
    Nov 2017
    What the heck?
    So the 10T cog can't fit, or will not sit directly on the new microspline hub, but holds onto the next smaller cog?
    Than why even bother making a new freehub design?
    They could have done this with the old HG design too by making the hub bodys lenght a little bit smaller.
    And even if the microspline body has more splines this won't do any good for avoiding some gauging, right?
  27. #1427
    Reputation: uzurpator's Avatar
    Dec 2005
    Quote Originally Posted by OneTrustMan View Post
    Yes. That is the design. Pretty much the same as XD does.
    They already did, years ago on a Capreo groupset. HG freehub is designed to be made of steel - whence shallow splines and just 9 of them. Worked fine on road cassettes in 1984. On mammoth 50T mountain cassettes of 2019 - not so much.
    Depends. Stamping is not a hyper-precise process so a new cog needs to seat itsself on the spline before it is held on it securely. From the pictures provided - it seems to be cosmetic only. My CK freehub with stainless steel body had such marks as well.
  28. #1428
    Jan 2016
    This is getting long.
    A resune
    - more $$
    - more issues
  29. #1429
    Nov 2017
    Quote Originally Posted by uzurpator View Post
    That's not what I mean.
    XD does not have splines. But if the smallest cog on a splined alloy hub isn't directly on the hub, wouldn't this put more pressure on the other outher splines?
    And I agree on the rest of your answers.
    We will just have to wait for at least 1 years reviews I guess.
    But I still think steel is the way to go for this new design aswell.
    I had steel HG hubs and the only thing you need to watch out is rust in winter.
  30. #1430
    May 2018
    The 10t has shallow external splines of a sort that seat into a matching recess on the 12t, they are both steel and once they are assembled together they are essentially one piece, directly under the lockring and engaged on the splines of the 12t to the freehub body. The same splines are taking the load from both cogs, but only one at a time so there won't be any excessive loading on the freehub. That entire stack of 4 loose cogs could be made in one piece, but that's not how Shimano has ever done it and I don't expect they are going to change now since it has worked well for them for a long time.
  31. #1431
    Also the smallest sprockets as loose is great so you can change them once worn out. This is especially important in e-bikes.
  32. #1432
    Quote Originally Posted by TurboKoo View Post
    Show me where you buy these.
  33. #1433
    https://www.sjscycles.co.uk/cassette...12t-y1x498020/
  34. #1434
    Touchť. Those donít really wear out for most of us, itís usually the bigger gears that slip first.
  35. #1435
    Oct 2015
    True, the new XTR does shift very smooth. But the larger cogs being softer than steel to get the weight down vs all one unit is my only turn off.
  36. #1436
    If thatís your concern you can just use SLX cassette as that has only one alloy sprocket and rest steel.
  37. #1437
    Jan 2009
    My xtr rear mech is almost a year old now... Has tonnes of side to side play with no chain on, my mates brand new one doesn't have this at all, so not entirely sure what's worn on it but it's very loose, and my shifting has gone pretty crappy too
    I'm 6 motnhs into the xtr cassette and altho it shifts OK it's not super smooth up and down the cassette, it's hesitant in various gears and clicks in some gears
    I have setup exactly the same a few times now just incase I missed something but its not the saem quality from new
    I don't expect it to be though but if the mech play is causing it more so then I need to take a look at getting it warrantied
    I'm going to post a short vid of the play in the mech later today to see if you think it's normal
    Will be pretty disappointed if my cassette is worn 6 months in, I swapped the chain 3 months in to make sure I didn't over use it and wear the sprockets
    If the mechs buggered ill likely get a new xt mech and xt cassette hopefully then it will work like new again
  38. #1438
    Jan 2016
    Have you been shifting under load?
  39. #1439
    Jan 2009
    yeh I guess so, ive been using it as I would any other drivertrain, one of the benefits is how smooth it is under load, I cant say as that's really changed much in terms of quality, its more niggly little things like slow shifting, and clicks, and then randomly jumping on some smaller cogs when trying to shift up - again reset all numerous times so not a setup issue and ive put a new mech hanger on just to check
  40. #1440
    damned rocks...
    Dec 2014
    It's just the cage that have play, or it's across the entire derailleur's body?
    If it's just the cage, you may have worn the seal between the cage and the derailleur's body. It's a seal but it also works as a kind of bushing and you can replace it.
    For the RD-M9100 goggle Y3FA62000 -- P-Seal Ring.
  41. #1441
    Jan 2009
    Quote Originally Posted by Aglo View Post
    im really not sure if its the cage, if I pull at the lower jockey wheel area of the cage, you can really feel it being loose/play, it almost feels like a screw is half loose or something
    I kinda from feel think its nearer to the mech itself (around the pins that shift the spring up and down the cassette) but its really hard to tell, I believe shimano is 2 yr warranty so I will be trying my luck at that first rather than taking it all apart
  42. #1442
    Jan 2009
    just for refernce - cassette since brand new has done 766 miles (there abouts!) ive had 2 chains on since new....so not a huge amout of mileage, very gritty mucky riding mind including summer and probably 100k+ vertical feet climb in those 766 miles (live in a hilly area)
    mech was brand new October 19 when xtr was first released - so its either the play on the mech or the wear in the cassette....
  43. #1443
    My main bolt into the hanger came loose after a couple of months. Had the same symptoms you describe. Check that first. It's been fine since (January).
  44. #1444
    Jan 2009
    Quote Originally Posted by andynunn View Post
    ive had the mech off the hanger several times, if you just mean the bolt that attaches it to the mech drop out hanger?
  45. #1445
    Yes, that one. In 30 years I've never had one come loose before but it was awkward to put back as the pivot seal was loose and kept getting trapped. It wasn't just the bolt loosening. The whole pivot assembly came apart just a bit. It looked OK but there was a lot of play at the cage and the shifting was slightly off.
  46. #1446
    Jan 2009
    cheers - thought you meant that one, I have had it off a lot and cleaned and checked everything, tbh it feels like the play Is mostly around that area somewhere but I cant pinpoint exacltly where, its just more obvious when you push side to side on the lower cage as its more exagurrated further away from the mech
  47. #1447
    Jan 2009
    As promised video of my mech
    https://youtu.be/tzTmOhZGzcM
    Doesn't look right at all, when I move it, it doesn't return back, it's all sloppy and floppy like the pivots or pins have given up... I guess my upshifting is crappy as there appears to no tension in the mech.. Just doesn't look right and not how I remember it being new
  48. #1448
    Where are you located? I would ask LBS to check warranty on that.
  49. #1449
    Jan 2009
    I'm england.... Yeh I'm going to send it off to them and he's said hell send it in for warranty
    Not normal at all, not sure what's happened it's just 11 months old, but it's not been battered or anything, hoping they warranty it as its got a 2yr warranty on xtr stuff and they are a fortune to replace
  50. #1450
    You sure you need to involve the LBS? Its one thing I like about Shimano vs Sram. The one thing I needed warranty on I went straight to Shimano US.
    Ripley LS v3
    OG Ripley v2 handed down to son
  51. #1451
    Jan 2009
    Quote Originally Posted by TwoTone View Post
    Yeh we have to send it via the importer for shimano which is madison, as far as i know there's no direct shimano hq in the uk
  52. #1452
    Dear XTR's.
    After running set of XTR 900 and Sram 11x casette it's time to 12x switch.
    Unfortunately mentime i've moved to new bike and 12x157 RF wheels.
    Is there a freehub from RF compatibile with micro-spline?
    Can i mix sram 12x casette and Shimano 9100 drivetrain (to keep XD freehub)?
    Does 10-51 casette require SGS or can be used with SG?
  53. #1453
    Oct 2013
    Answers below
    QUOTE=Placek;14421395 - Dear XTR's.
    Check with RF
    Yes, watch this - https://youtu.be/g4l_O1qtJ8I
    Does 10-51 casette require SGS or can be used with SG? /QUOTE
    There's only SGS offered by Shimano, look for M7100/ M8100/ M9100 derailleurs.
    2019 Yeti SB100
  54. #1454
    Answers below
    Check with RF
    Thanks a lot.
    Questions.
    1. Can i use the regular SRAM 11x freehub with new 12x SRAM casette?
    2. Can i use new xtr 9100 chain with sram 12x casette and 12x Shimano dir?
    3.
  55. #1455
    Jan 2019
    Quote Originally Posted by Placek View Post
    Thanks a lot.
    Questions.
    3.
    1. No.
    2. Yes.
    3. Maybe.
  56. #1456
    Oct 2015
    Just upgraded to the new XT M8100 after patiently waiting it out despite the Eagle's availability.
    Boy is it god damn worth it. The shifting is simply sublime. Can't wait for HG+ to trickle down to the next road 12 speed group.
    One thing for sure, I finally need to upsize my chainring to 34T. The cassette ratio really does allow you to go 2T higher than sram eagle equivalent.
  57. #1457
    Jan 2002
    im sure this has been covered here but im admittedly being lazy.. :
    Can i use a Sram Eagle 12spd chainring w/ a Shimano xtr 12spd chain?
    (obviously in conjunction with 12spd xtr cassette/der/shifter)
    thanks
  58. #1458
    Mar 2011
    could anyone tell me if an 11 speed chain will work with 12 speed chainrings?
    looking at upgrading my cranks on my 11 speed drivetrain.
  59. #1459
    Nov 2016
    Quote Originally Posted by hiss2 View Post
    thanks
    Nope, has to be an HG+ one.
    Sent from my SM-N975U1 using Tapatalk
  60. #1460
    Reputation: 04 F2000SL's Avatar
    thanks
    When using regular 12 speed rings you need a sram quick link as the shimano link is too narrow. I use sram link with raceface ring on my bike.
  61. #1461
    Quote Originally Posted by MagicShite View Post
    ????? Huh, How does the math work on that one?
    10-12-14-16-18-21-24-28-32-36-42-50
    10-12-14-16-18-21-24-28-33-39-45-51
    The effective change between the two cassettes on a gear ratio and gear development plot isn't significant, especially not a 2T increase on the Chainring!!
    In effect you're just trying to equalise the gear ratios so you get the same speed. Why bother??!! In fact you wil reduce your effective gear range because if you're running a 32T on the SRAM drivetrain you still won't be strong enough to handle the taller midrange and top end gearing
  62. #1462
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Quote Originally Posted by Brad View Post
    His username checks out...
  63. #1463
    Quote Originally Posted by brex17 View Post
    1. No.
    2. Yes.
    3. Maybe.
    A bit concerned.
    1.Last year XD freehub is listed as 11 and 12x than?
    2. Which chain would fit better to Eagle casette and Shimano 9100 dir?
  64. #1464
    Oct 2015
    Sigh
    I made the math on another thread
    https://forums.mtbr.com/drivetrain-s...l#post14282425
    In essence, when you climb anything of significance (real long and steep climbs), the most important thing are the last three big cogs of the cassette. How well you can play with those is important. Using 34T on the shimano cassette, you only lose about .1 ratio from the sram equivalent with a 32T.
    Using 34T also allows you to go slightly faster on the flats without using the 10T too much, which is VERY important before entering the slow grindy single tracks. I see it as a win win.
  65. #1465
    Sigh
    I agree, I have a 36 on my XTR bike and the top three are way better than the SRAM gearing when your pushing the limits of required climbing gears. I actually run a 38 on my AXS bike but it's a fixed seat XC rig more oriented for faster flater trails.
    I also find AXS to be a better drivetrain for shifting accuracy when your really gassed. XTR I prefer for more tech and shifting under climbing loads. AXS clutch also is not as strong take that for what its worth.
  66. #1466
    Sigh
    Maybe in theory, but with a lot of high level racing behind me over the last few seasons, I'd say in practice, it's cadence that is a much more determining factor. Spinning a fast cadence is not always comfortable, but almost always faster in the long run, more efficient for your muscles so it saves them and still makes you go faster. Although most top level racers don't need ridiculous combos like 28x52, they also don't see any benefit from lugging around big chainrings, because even when you have these bigger/high gears, you simply don't pedal them fast enough cadence-wise to really be faster and efficient. It's more resistance, which sometimes feels good, but IME, there's no actual benefit. I'm not saying that no one should run a 34, just that the logic of running it to make you go faster isn't sound in my experience.
  67. #1467
    since 4/10/2009
    A bit concerned.
    SRAM uses the same freehub body for 11spd cassettes as for 12spd mtn cassettes. There's ZERO difference. There is an XDR freehub body, but that's road only, and requires a totally different hub. It's not relevant here.
    You're better off matching cassette and chain brand. You COULD use a Shimano chain with an Eagle quick link, but what's the point when you could just buy a SRAM chain and use the included quick link? You could use a KMC 12spd chain if you prefer those.
  68. #1468
    For regular people that don't get a new bike every race it's best to use the largest ring you can. I run big rings because using a 10 tooth sprocket is unrealistic unreasonable and can slip very easily. Small sprockets wear extremely quickly and it's easy to kill a cassette in the small sprockets in a single long ride with a few road transfers. XTR 10 tooth is only engaged with a single tooth on the chain... if you aren't using your pie plate you should up your chainring
  69. #1469
    since 4/10/2009
    Quote Originally Posted by 04 F2000SL View Post
    the above seems to contradict the below, in all honesty.
    I don't agree with this method of selecting gearing. For one, a 10-51 cassette is most likely more RANGE than the majority of riders are going to use. It's a big part of the reason I selected the 10-45 cassette to build my drivetrain around. Problem is, Shimano was only thinking of racers when they considered that cassette. And that "regular" riders would all gravitate towards the 10-51 cassette. Frankly, I have no desire to go back to super long cage derailleurs. I'd rather run the shortest cage I can for crisper shifting, better chain stability, and keeping the derailleur away from trailside debris.
    I'm definitely a midpack "mortal" rider. I care about having low end for big/long climbs. I don't much care about big top end gearing because if I'm going that fast, I'm coasting downhill or I grab a different bike. There's a couple things I look at when I'm selecting gearing. For one, I want to maximize the range of the cassette that I actually use. Both ends of it. It spreads wear across the cassette rather than focusing it any particular place. I also look to run the chain towards the middle of the cassette for most of my riding for straighter chainlines. I also look for the big cog to be what I use on the biggest, steepest climbs or for smaller ones only when I'm trashed from a hard ride.
    I started with a 30t chainring in my drivetrain because that's the smallest that any of the aftermarket companies are making for my cranks (RF) that's officially compatible with HG+. It put me in the big cog on the cassette too much, and was still too tall of a gear for the steepest, longest climbs. I found that I was blowing myself up super early on my rides and it wasn't good. I went back to a "not compatible" 28t chainring using the Eagle quick link to make it work in order to get the gearing I wanted. It has the benefit of also being steel, so it's cheap and durable, and I really don't need to worry about it wearing out super fast.
  70. #1470
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    I'm a stronger rider and you should use what suits your terrain. We have 20%+ grades and need the 30x50/51. Even then I'm outside of my optimum range in some spots, dropping down to sub 60 rpm. I almost never use my 10 tooth on dirt, so it will last forever.
    On my race bike I need the top end and use a 32 for the sprints and pacelines. It's no fun to climb on at non race pace though.
    Most recreational riders should be sizing down and keeping the RMP higher. Pushing a big gear is always slower.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
  71. #1471
    A 32 is not going to wear "extremely quickly" compared to a 34. I agree with if you aren't using your full range of rear gears that you need to up your chainring size, but sometimes that's only because you don't ride the steeper/extended stuff as often. I find for normal riders AND racing that not having a 34 or 36t front ring does NOT hold them back in terms of speed.
  72. #1472
    So i need to be more detailed
    I'm using RF NarrowWide Oval chainring so it looks i can't use Shimano chain.
    Can i be safe with Sram or aKMC chain ( with 1295 casette)?
  73. #1473
    Mar 2017
    You can be safe with one of those yes. But you will get better performance if you use a shimano chain with a sram powerlink in place of the shimano one. You absolutely can run a shimano chain with that chainring, you just canít use the shimano quick link.
  74. #1474
    Nov 2017
    Has some of you already worn the alloy cogs on the XTR cassette? (10-51)
    Two daya ago I met a biker with an XTR drivetrain, but with a Sram XX1 cassette.
    When I asked him why I said that the new XTR cassette ist wearing way too fast.
    Especially the 39t cog which is also made of alloy
    The region there has lots of long and steep climbs. So most of the time you have to use the biggest cogs on your cassette.
    He was very disapointed and after trashing the alloy cogs a few times he switched to the XX1 cassette which he said lasts like forever.
    I think if you live in such a region were you have to climb a lot the XT cassette should be the better choice.
    What are your experiences so far?
  75. #1475
    since 4/10/2009
    Quote Originally Posted by bronxbomber252 View Post
    No point in using the Shimano chain and THEN replacing the quick link when you're using a SRAM cassette. Pick a SRAM chain or KMC chain (and use the included quick link) if you're using a SRAM cassette. Doesn't matter which. Pick what's cheap/on sale/what you prefer based on prior experience, or whatever. Using a Shimano 12spd chain on a SRAM cassette confers zero benefits of HG+ shifting, and may in fact be a touch worse because it's built to be used with a Shimano 12spd cassette that has slightly different cog spacing than SRAM 12spd cassettes.
    I haven't had any problems. I spend a decent amount of time in the bigger cogs, too, because I have quite a few long and fairly steep grades. I'm on the 10-45, but the 3 biggest cogs are still alu.
  76. #1476
    Apr 2018
    not at all. mine has been solid.
    my rides are all well over 2500ft of climbing grinding in the lowest two gears. i run pro gold extreme chainlube for what it's worth, and clean plates and pulleys with alchohol and re-apply after every ride. i wash cassette and chain every 6-10 rides. i run a pretty high cadence though, like 100-110.
  77. #1477
    I have a couple of the 45T cassettes.
    The oldest probably has 2K miles on it....and spent a lot of it's early life in New England mud and water....and a few hours with a very bent derailleur hanger
    Still going strong.
  78. #1478
    Jul 2017
    Quote Originally Posted by FactoryMatt View Post
    Well, you said basically nothing about the durability.
    What mileage are you getting on the cassette and chain?
  79. #1479
    Quote Originally Posted by gustavo.ghd View Post
    I have around 90 hours on a XTR cassette 51 tooth. I find durability of the larger cogs to be less than steel obviously but no means quick wearing. I'm not the best about washing and cleaning it all up when conditions are dry and I'm riding every single day in prime summertime.
    The chain rubs the adjacent gears a hair and wore some of the larger cogs sides down but other than that it's been excellent. This might damage shift ramps a bit
  80. #1480
    Apr 2018
    ive got at least 800 miles each on two different cassettes and chains.
    10mph average and 1200 ft/climbing per 10 miles.
  81. #1481
    West Chester, PA
    Confirming - I have to use a sram quick link on the shimano chain for it to play nice with an absolute black chainring?
    My time with eagle has come to an end. Getting tired of the random clunky shifts. Ordered xtr cassette, xt shifter and slx derailleur.
    By the way - There is a seller on ebay currently selling the XTR cassettes for $263
  82. #1482
    Mar 2017
    Quote Originally Posted by 92gli View Post
    By the way - There are a seller on ebay currently selling the XTR cassettes for $263
    Yes, unless you have a Shimano crank and get their shimano 12sp specific chainring
  83. #1483
    For those using non Shimano 12sp chainrings with sram quicklink, have you noticed chain or cranking wear?
    Have a bike with truvativ decedent crank coming but am going to swap to Shimano shifter, RD, chain, and cassette. From what I read this will work with a SRAM quicklink, but curious if it kills the chain.
  84. #1484
    Guys
    Would that setup work.
    RF crank with Narrow Wide chainring, sramm xx1 chain, Eagle 1295 casette, xtr 9100 derailleur and shifter?
  85. #1485
    member member
    Reputation: twowheelmotion's Avatar
    Feb 2010
    I came here just to say that very thing. I have been on XTR 9100 11-51 Since June, and have recently become very frustrated with it. Been ridden just about 3x a week consistently, since purchase. All was well in the beginning. Smooth, flawless shifting and quiet operation. Then about a week ago, I start hearing this mal-adjusted sound, almost like its a barrel adjustment issue where the chain was skipping and wanting to ghost shift. Nope. Not out of adjustment..
    After hours of trying to figure out the issue, turns out that the interface from the hub body to the cassette body has such minimal contact points, that the cassette body actually stretched and ovalized. Basically, "Pringled" on both sides of the XTR cassette body. Grrrrr..
    So what was happening, was one "ring" and the other opposing "ring" were worn and the 1-piece cassette had so much play in one direction, that even if I cranked the lock ring down to +40nm, the cassette was still loose AF. Still loose enough to where once I rode the bike, the cassette would go cockeyed, again, and VIOLA the chain would want to ghost shift.
    If you have seen the XTR cassette, there are 2 opposing, and minimal contact points that are isolated from each other, rather than a sleeve-type with maximum contact, like old HG. Good thing is all XTR is guaranteed for a few years, because it's warranty time!
  86. #1486
    Jan 2016
    Quote Originally Posted by twowheelmotion View Post
    So the 20S costs much less and last much more??
    Old is proven, old is good, old is gold.
    Keep shifting under load, i am too old to learn that trick.
  87. #1487
    West Chester, PA
    Just checked to make sure the xtr cassette I ordered on ebay is from an authorized dealer. Whew! It is.
    Would like to see some pics of what you described twowheelmotion. What brand hub are you using?
  88. #1488
    Jul 2017
    No surprise you have no issues, that is nothing to evaluate on durability.
    XX1 and X01 cassettes are reported lasting over 6k miles.
  89. #1489
    Hi twowheelmotion, did you have the lockring tightened to 40nm from new? Cheers
  90. #1490
    member member
    Feb 2010
    Quote Originally Posted by PuddleDuck View Post
    Uh huh. Sure did. Torque spec to 40nm with a my trusty Shimano Pro torque wrench, using the applicator, the spacers the new super-sweet Shimano grease. It's XTR... Moment so special I had a bottle of wine open and Marvin Gaye playing on the HiFi, too.
  91. #1491
    Guys
    Anyone?
  92. #1492
    Oct 2013
    Anyone?
    It would work just fine, used it racing this past season - https://youtu.be/g4l_O1qtJ8I
    Also a playlist with a lot more details of the Shimano 12 speed drivetrain. Enjoy!
    https://www.youtube.com/playlist?lis...KJP6ciHmRoN3sa
    2019 Yeti SB100
  93. #1493
    Full XTR. Special. Almost worthy of a live performance with full orchestra.
    Which hub are you using?
    I hop that you keep us informed about what Shimano say/do.
  94. #1494
    member member
    Feb 2010
    Definitely will... So.. I placed the order in April 19' before the entire XTR group was completely available to ship. Problem at that time was the limited amount of companies that were doing the new hub design. Even Shimano didn't have the hub to ship. Contemplated running some frankenwheel with a DT Swiss driver, but ended up going with a wheelset from NOBL, Canada. NOBL sold me Carbon 38's on I-9 101's and they included the I-9 microspline driver. Jury is still out on the 101 hubs...
  95. #1495
    I'm interested in why you're not convinced about the 101 hubs. Is it this issue, or something else?
    If you have any concerns about I9 product, you should contact them, I've found them to be very helpful and responsive to both general questions and specific issues.
    They may want to know about this anyway - lest this is somehow specific to their freehub (in which chase they would look after you), or others start blaming them without reason!
  96. #1496
    This is what i needed exactly.
    Thanks a lot.
  97. #1497
    member member
    Feb 2010
    Firstly, I-9 is, and has been a great company, to me. I would never forsake them, and has nothing to do with the microspline. I just had a little hiccup with the front hub. Noticed the wheel had a little a little play from side to side. Explained to I-9 what the problem was, and they shipped a replacement end cap for the drive-side. Part showed up to the shop a few days later at no cost, and that seems to have fixed the issue. Good times.
  98. #1498
    So still no word on a firmware update for XTR Di2 for 12 speed?
  99. #1499
    Professional Slacker
    Quote Originally Posted by BlownCivic View Post
    It's going to require a new derailleur, there won't be any quick flashes from 11- to 12-speed.
  100. #1500
    Jan 2019
    Bonking ... not feelin' well XTR M9100 rear derailleur rock strike!!
    I have just noticed this damage to the body of the rear mech which I presume was caused by a rock. I only noticed when the bike was upside down so could have happened awhile ago. It's still working fine and I think it is the whole body and not replaceable. Anybody had the same happen or any repair suggestions?[ATTACH=CONFIG]1295625
    Attached Thumbnails Attached Thumbnails 2018 Shimano XTR 12-speed-dscn2402.jpg
  101. #1501
    West Chester, PA
    Quote Originally Posted by MBO Rider View Post
    Interesting. I just went to look at my SLX mech to see if that piece is plastic; it is. Thought maybe they used plastic on xtr to shave a few grams. On a related note, the plastic clutch switch feels pretty flimsy as well. Can you move your switch to off position?
    I suspect you'll have to replace the whole bottom half, if it's even available.
  102. #1502
    Nov 2019
    Quote Originally Posted by gonzo2213 View Post
    I had the exact same question. I wanted to put the MT900 crank on my existing 11 speed system to save a little weight. I talked to Wolf Tooth to get their thoughts on it (I'm running a WT chainring now) on the presumption that they have quite a bit of engineering knowledge on the differences between the old 11 speed and the new 12. The gist of what they said was that the tooth profile is different enough (deeper valleys between the teeth, the additional beveling on the teeth, etc.) that you'd wear stuff out pretty quickly. Their opinion was that it is inadvisable bordering on incompatible to run a new 12 speed chainring with an 11 speed chain. Incidentally, WT has no plans to make an 11 speed chainring for the new Shimano direct mount cranks. I asked.
  103. #1503
    Jan 2019
    Yes the Clutch lever is fine moving smoothly and still working. I tried to find an exploded view pdf of all the rear mech parts like Shimano normally have but with no success
  104. #1504
    Jan 2019
  105. #1505
    Jul 2018
  106. #1506
    West Chester, PA
    The white industries freehub is a nice piece
  107. #1507
    damned rocks...
    Dec 2014
    ^that falls into the category "bike porn".
  108. #1508
    May 2018
    Quote Originally Posted by Carpetbombing View Post
    I'm thinking WT is playing it safe with that advice. I would be surprised if there is any issue running 11sp chains on any of the Shimano 12sp specific chainrings. Internal dimensions are basically the same.
    The other option is to run 12sp chains on your 11sp drivetrain. I know this works well, I use X01 Eagle chains on my 11sp bike and it works great. I have tried XTR 12sp chains on it too, and the chainring was a minor issue, but using the MT900 cranks would eliminate this from being a concern.
    I have one bike that is pure 12sp XTR, and one that is a mishmash 11sp(currently XTR 11sp derailleur and Garbaruk 10-50 cassette with X01 chain and XTR 11sp cranks with WT chainring, previously X01 cassette and I have run it with XTR 12sp chain), and while there is a benefit to the XTR cassette+chain combination in Hyperglide+, the drivetrains both work quite well.
    Bottom line, any 11 or 12 speed bike I wasn't using a HG+ cassette on, I would use an X01 chain, due to the way it's made it's a very durable chain without the extra bling tax of XX1.
  109. #1509
    Nov 2017
    Looks great!
    Is it a steel body?
  110. #1510
    Reputation: Myers005's Avatar
    Jan 2011
    Looks great!
    Is it a steel body?
    Titanium
  111. #1511
    Nov 2017
    Quote Originally Posted by Myers005 View Post
    Titanium
    Thanks.
    White makes some really great looking hubs.
  112. #1512
    Dec 2014
    .... I started with a 30t chainring in my drivetrain because that's the smallest that any of the aftermarket companies are making for my cranks (RF) that's officially compatible with HG+. It put me in the big cog on the cassette too much, and was still too tall of a gear for the steepest, longest climbs. I found that I was blowing myself up super early on my rides and it wasn't good. I went back to a "not compatible" 28t chainring using the Eagle quick link to make it work in order to get the gearing I wanted. It has the benefit of also being steel, so it's cheap and durable, and I really don't need to worry about it wearing out super fast.
    Quick question: So your chain length measurement was set up initially for the AB 30T chainring? When you changed that to the AB RF 28T chainring, did you have to reduce your chain length by one link?
    I only have the AB RF 28T oval chainring now (with my XTR 11 speed group) and I intend to keep that chainring. However, I at some point I would like to use / test the new AB 30T RF chainring but I am afraid that my chain will be too short if I go up 2 teeth on my chainring.
    Thanks in advance to your response.
  113. #1513
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Just experiment with extra master links, it wonít hurt anything.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Thrill Bikers Unite!
  114. #1514
    West Chester, PA
    As much as I admire how Sram machines their cassettes, this is very cool in a different way
  115. #1515
    Aug 2015
    I can use a crankset/chainring 1x11 m8000 34t with the rest m8100?
    I read that the shimano 12spd chain doesnt fit this chainring 1x11. Options?
  116. #1516
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Quote Originally Posted by Thiagooo View Post
    https://www.wolftoothcomponents.com/...perglide-chain
    Change begins by doing something different.
  117. #1517
    Mar 2011
    So I bit the bullet and bought XTR M9120 12 speed cranks to go with my 11 speed drivetrain. I've only done one short race, but it seems to work fine.
    I guess the jury is still out with long term wear....
  118. #1518
    Oct 2013
    It works because the 12 speed chainring teeth are skinnier to make room for the beefier inner plates of the chain. Interesting if the chain retention is as good with an 11 speed chain that should fit loosely on that chainring compared to the 12 speed HG+ Shimano chain. I would love to hear your feedback on that.
    2019 Yeti SB100
  119. #1519
    I have one of the 4-material (carbon, aluminum, steel, titanium) cassettes. It's good, but relatively heavy. As you say, it's still an impressive piece...one could say they have had to go to even great engineering extents to try and get the weight down, so again, impressive. I have one of the old HG drivers around to switch out to cheap summer commuting drivetrains, so I might buy another one of those high end 4-material cassettes for it for the winter use.
  120. #1520
    Apr 2018
    They hold up super nice. Totally conjecture here, but the alloy they use for the big sprockets is special stuff. Holds up wayyy better than my sram xg1190 cassettes. Still looks new almost after tons of miles.
  121. #1521
    Oct 2015
    What conditions? And What lube do you use? I demoed the XTR and really like it. But I'm concerned about so much alloy. And don't want the heavy SLX cassette.
  122. #1522
    Apr 2018
    Quote Originally Posted by Cerberus75 View Post
    Dry moondust and pro gold extreme. I clean chain with alchohol after every ride and reapply light coat. I weigh 78kg and spin alot.
    I spend alottt of time climbing in the big cogs. They get used.
    Nothing to worry about i think. Theyve been solid.
  123. #1523
    Feb 2017
    I have 12s SLX crankset with 32T which I'm running with 11s SLX chain in a 11s setup (XTR der and both sunrace/shimano cassettes). I've only had four one hour rides but so far but those with zero problems. But I'll consider using 12s X01 chain too. Though I'm not worried about wearing out the steel shimano chainring quickly.
  1. 2018 Shimano XTR 12-speed
    By fc in forum California - Norcal
    Last Post: 05-26-2018, 11:21 AM
  2. Replies: 20
    Last Post: 09-11-2015, 12:33 PM
  3. SRAM PG-1170 11-36 with Shimano XTR 11s rear derailleur and Shimano XTR 11 shifter
    By look_as in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 12:21 AM
  4. Shimano XTR 10 speed vs sram X0 10 speed
    By carbon crunchy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-25-2011, 09:39 AM
  5. Shimano XTR M980 Shadow 10 Speed Rear Mech and 9-speed system...
    By xr_mtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 08:08 PM
Members who have read this thread: 751
