Results 1 to 6 of 6
    Mar 2014
    1x10 to1x11 via M8000 Cassette
    I currently have a SRAM x9 1x10 11-42 (OneUp) setup on my bike with a RaceFace Narrow-Wide chainring. Since the M8000 cassette claims to fit 10-speed freehubs, I should be able to buy the cassette, a SRAM X1 11speed shifter, a 11-speed chain and call it a day, right? I like the 11-42 okay, but having an extra gear to smooth things out would be nice.
    Since both the X1 and X9 are exact actuation they should be compatible. The only incompatibility I could see is the 10-speed pulleys on the rear derailleur with the 11-speed chain.
    Reputation: RS VR6's Avatar
    Never thought of it that way. Not sure the 10sp X9 has enough range?
    Sep 2012
    Yes, you are correct. That is pretty much how I went XTR 1x11. Shifter, cassette, and chain.
    My Giant's - 2014 Propel Adv Di2 - 2014 TCR Adv SL4 - 2014 Anthem Adv 27.5 - 2014 XtC Adv 27.5 - 2014 TCX Adv Pro
    I would be interested to know if this works. My "guess" is there is a reason Sram Engineers went through all that hassle to create a totally different type of der for 11sp. But it could have also been from a marketing standpoint too.
    Mar 2013
    Quote Originally Posted by jonshonda View Post
    Not totally different but the way it pivots is different for 10 vs 11spd... not to say that it won't work, just not ideal.
    Additionally, the SRAM 1x stuff is not compatible with 2x setups, as the derailleur only moves horizontally and cannot accommodate the difference in chainring sizes that comes with a 2x setup changing gears.
    Reputation: davesupra's Avatar
    Sep 2013
    I'm using an X9 deraileur on an 11 speed, works perfectly.
    https://youtu.be/FPtOIy0xn2U
    DaveH
    '15 Salsa Horsethief
    '13 9:ZERO:7
    '13 Trek Domane
    '16 Salsa Fargo
  1. m8000 11-42 cassette fits dt swiss 10sp mtb hubs
    By markymark in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-14-2015, 06:31 PM
  2. XT M8000 Cassette with SRAM shifter/derailleur
    By Triggsie in forum Components
    Last Post: 09-27-2015, 12:25 PM
  3. Will Xtr m9000 RD work with Xt m8000 11-42t cassette?
    By yeti575inCA in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2015, 02:34 PM
  4. Ext Range 1x10 vs OEM 1x11 (m8000)
    By minimusprime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2015, 02:14 PM
  5. Any info on when the Shimano m8000 11-42 cassette will be available?
    By SB666 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-11-2015, 10:38 AM
