12spd XTR skipping with oval?- Mtbr.com
Results 1 to 10 of 10
    Mar 2011
    Just put an oval (blackspire) onto a pair of m9100 12 speed XTR cranks, going back to matching XTR derailleur + cassette. Bike rode just fine before, but now in the middle of the cassette, it will jump gears and skip around under load as the oval cycles. Top and bottom of range seem to be OK. If the bike wasn't running perfect ahead of time I'd suspect a bent hanger but since the only thing I swapped was the oval - wth is going? Do I need to adjust or rebuild the clutch? The drivetrain has about 1k miles on it so far.
    Jul 2017
    Is the blackspire chainring designed for hyperglide+?
    Sent from my LIO-N29 using Tapatalk
    Mar 2011
    Supposedly yes. Although I still haven't ascertained exactly what hyperglide does or means exactly.
    Mar 2011
    Well I had assumed it was well tuned from the previous owner since it shifted pretty well with the round ring but it looks like the b screw was way out of adjustment. Got that dialed in and reset cable tension and it seems to be better. Some upshifts seem to bind depending on the position of the oval and the chain is rubbing the end of bash guard when in the granny however. Closer, better, but not quite there yet.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by B. Rock View Post
    Oh, a secondhand bike?
    Yeah, all bets are off on adjustments/service.
    IME, 12spd drivetrains like things to be adjusted "just so" and require a decent amount of precision during the setup to get them there. Once set, I've found Shimano's 12spd, at least, to be pretty reliable in holding that adjustment.
    Jan 2019
    Could also be clutch adjustment. The oval makes the derailleur cage move a little bit, so you may need to turn it out an eighth turn or so.
    Mar 2011
    I was wondering about the clutch. I'll give that a go, thanks.
    And yeah - second hand but came from one of the guys at a bike manufacturer so I thought it would have been pretty dialed.
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Make sure the clutch is lubed appropriately per Shimano's instructions. I recall hearing some made it out dry. Is the chainline the same as the original chainring?
    Mar 2011
    Yeah, both 52mm chainline.
    After I started from scratch and retuned the whole thing, it seems to be way better. Guess I just got lucky that it was working with the round ring being so far out of tune but it's much more sensitive with the oval. Good to know.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    I put an Absolute Black oval on my XTR 12 for my last endurance race (34T round to 32T oval) with a new chain. No difference in drivetrain performance.
    THough I think I am going back to the round and only using the oval for longer endurance events. Maybe a 34T oval is more ideal.
  1. Shimano 12spd oval chainring options
    By The Moops in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2020, 12:04 PM
  2. XTR 12spd conversion questions - will this combo work (M9000 crankset + DT R hub)
    By R332 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-14-2019, 10:25 AM
  3. Shimano 12SPD Shifter - 12SPD Cassette - 11SPD MECH
    By PHeller in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-20-2019, 10:58 AM
  4. To Oval or not to Oval?
    By big0mike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2018, 05:14 PM
  5. Oval to round to oval to round to...
    By Lenny7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2015, 07:11 PM
Members who have read this thread: 62
