10 speed Shimano SLX M660 vs M670? What is the difference?- Mtbr.com
Results 1 to 6 of 6
    AllMountain+CwmcarnUplift
    Reputation: DIESELindustry's Avatar
    Hi there guys.
    I cant seem to find the difference between the SLX M660 and M670 shifter?
    Can anybody help? I've been given a 10 speed M670 left and need a right. I would like to match them.
    Thanks in advance
    If your not falling off, your not riding fast enough!
    Cube Fritzz 2008
    GT Aggressor XC 1
    A guess - Maybe cosmetics only, but there could be a trickle down of technology from XT
    Reputation: RS VR6's Avatar
    I think the 660 is 9 speed.
    Reputation: Aresab's Avatar
    The M660 is the older model and did come in 9-speed and 10-speed (like M770). The M670 has a newer style as well as the newer upshift lever cover (small lever to shift to higher cogs) which is a metal lever underneath. It also has a 2/3 speed front shifter converter which is very minor since all it does is lock the shifter in front gears 2 & 3 bypassing the granny gear. This is to accommodate 2X cranks (not 3X cranks with a bash since you don't need the mode converter for that).
    Just skimming the internet it looks like the 670 has the 2/3 speed switch and has an I-spec version. Probably the cover design has been modified for that.
    Thanks guys. Looks like Its not that big a difference really but I got a M670 for just under 24 which is the cheapest online.
    also great bit of info about the x2 and x3 setting on the Front shifter. I would have most probably tried to use it in x2 mode thinking that because I was only using 2 chainrings that it would work. I am going to run 2x +bash. I'm not fit enough to get rid of the granny haha.
    Cube Fritzz 2008
    GT Aggressor XC 1
  1. Shimano XT M780/785 and SLX M670/675 crankset chainline info needed
    By guim in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 05:46 AM
  2. Shimano SLX M660 Cranks with 10 speed chainrings
    By LukeSkywalker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-07-2013, 06:19 AM
  3. Shimano SLX M660-10 OE Crankset @ Jenson $89
    By mtnbikej in forum Where are the Best Deals?
    Last Post: 06-12-2013, 04:04 PM
  4. Shimano SLX M660 vs M670 crank?
    By svollmer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-29-2012, 03:19 PM
  5. shimano slx FD-M660 front derailleur adjusting
    By Andythemtbking in forum All Mountain
    Last Post: 12-22-2012, 07:39 AM
