    Sep 2014
    10 speed crank with 9 speed cassette and RD?
    I am trying to convert a 3x9 system into 1x9 by getting new crankset and 11-40T cassette. The problem is that there are not a lot of options for a single chainring 9-speed cranksets. Most of the ones within my budget are 10-speed. Would that still work with a 9-speed cassette? My RD is Shimano Deore XT.
    This is a budget conversion so that's why I am trying to keep the RD, chain and shifter.
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Yes it will work just fine. I used a 10 speed triple on my 9 speed for a while before I made the switch to 1x11.
    Change begins by doing something different.
    Reputation: LyNx's Avatar
    Yes, any crank will work if you're going to a 1x setup. My question to you is, what's wrong with your current cranks that you don't just use them? All you have to do is remove the inner and outer rings and then install the size middle ring you want, you could even use back your old middle ring if it's the right size and not worn out, but I'd highly suggest getting a new Narrow/Wide ring to help retain the chain.
    Sep 2014
    Thanks guys.
    I can't just remove the chainrings as the current crankset has a non-removable triple chainrings. I have to get a whole new crankset.
  1. Replies: 2
    Last Post: 07-05-2017, 06:24 AM
  2. 9 speed cassette to 10 speed cassette?
    By Josh_SL2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2012, 05:33 AM
  3. Dyna Sys 10 speed crank to replace 9 speed crank?
    By sunnyside in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2012, 03:02 PM
  4. Why use a 10 speed cassette over a 9 speed cassette?
    By Gary H in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-06-2011, 07:22 PM
  5. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
Members who have read this thread: 9
