1 x 9 Conversion - Trying to avoid a chain guide- Mtbr.com
Results 1 to 11 of 11
    Reputation: macming's Avatar
    I have a 3 x 9 setup with a 9 speed SRAM X0 shifters and 9 speed mid-cage rear derailleur (not a clutch type).
    I've done some research, and it seems like most people have great luck with a narrow wide chain ring. Assuming I get my chain tension properly, would a narrow wide chain be enough?
    If a clutch type derailleur is required, I see a lot of people had good luck with Shimano 10 speed derailleurs. Since most people like the Zee Shadow derailleur, I'm wondering if a XT or XTR derailleur will work as well. If they do, would a XTR M986 or M985 work?
    Thanks,
    Ming
    NedwannaB
    Reputation: JMac47's Avatar
    Couple things going on here
    Type of bike will determine the correct components.
    The Bionicon will help with chain slap on non clutch derailleur depending on chain stay configuration but if going 1x you'll still need front guide of some sorts unless you get a narrow/wide dropstop chainring.
    Ripley V1 XC/Gravel Adventure rig
    GT Carbon Sensor(future...)
    SS Salsa Timberjack
    Quote Originally Posted by JMac47 View Post
    The setup is for a Santa Cruz TRC, maybe a Nomad C as well.
    About the narrow/wide chain rings, do they work 95% of the time assuming I keep a very tight chain tension?
    I think it depends on the type of terrain you ride. I have several bikes setup with the NW chain rings and some have clutched derailleurs and some don't. I even have one bike just with a single speed chain ring.
    I have never dropped a chain on any of them. I tried running a normal 32 chainring and dropped chains all the time - any fast bumpy downhill dropped the chain.
    If you ride a lot of long rocky downhills with lots of drops then you are likely going to need a clutch. Otherwise, give it a try.
    When you ask about using a XT or XTR derailleur, are you intending to do the SRAM 9 speed shifter to Shimano 10 speed derailleur trick? Normally manufacturers and speeds have to match.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Try the narrow-wide with your current 9sp drive train and ride the bumpy stuff that you like to ride. Then you'll know. Not a lot of $ to find out.
    A non-clutch and narrow-wide has worked for me recently but still needs more testing so I am comfortable (or not) with the drop frequency.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Quote Originally Posted by Slash5 View Post
    Thanks! I think I will try my current setup without buying a new derailleur first. It's good to hear from other people's real world experiences.
    That is the plan! SRAM 9 speed shifters and Shimano 10 speed derailleur both use pretty much 1:1 cable pull ratio. They are supposed to work well.
    Quote Originally Posted by Glide the Clyde View Post
    Thanks for your input! I'm going to order a Raceface narrow wide when the time is right
    Aug 2014
    The n/w chain rings work really well. I've ridden 1x9 without a clutch or chain guide for about a year now and haven't dropped a chain yet. Hold off on a new clutch dérailleur unless you know you're dropping chains. If your derailleur is a long cage however it may not keep the chain as well in the rough. 10 spd chain works better than 9 spd (shifts good on 9 spd cassette). Make sure to properly size the chain. Look at Wolftooth for the ring. US made, good company, great product. Blackspire is also nice. Chromag also has n/w. I think theirs is licensed from SRAM.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    ^^^ Good information. My current setup is a 2x9 that I am planning on dropping to 1x9 and will be turning the bike into a monstercross bike. I am currently running a long cage derailleur on a horizontal sliding dropout frame so I may be better off going with a NW and a chainguide. Really wish I wouldn't have to but this will mainly be a commuter bike and gravel grinder with the occasional singletrack thrown in there.
    Aug 2014
    If it's only occasionally seeing single track, try without the chain guide first. You have nothing to lose. Just make sure to correctly size the chain. If this bike was seeing a lot of rocky, rooty single track I'd be more hesitant with a long cage derailleur. For your use just try the n/w ring with a 10 spd chain. You can always add a chain guide and/or a clutch derailleur if you're not satisfied.
  1. RaceFace Narrow/Wide 1x10 Conversion No Clutch or Guide!
    By NoahPhillips in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2014, 09:04 AM
  2. Mojo HD and MRP AMg Guide BB Mount? Will it work?
    By groundskeeperwilly in forum Ibis
    Last Post: 02-02-2014, 12:17 PM
  3. Truvativ X9 38-24 conversion and X-Guide
    By experiment70 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-28-2013, 03:52 PM
  4. Fox type fork brake cable guide for RockShox conversion?
    By fskywalker in forum All Mountain
    Last Post: 04-29-2013, 11:18 PM
  5. HD & E13 LG1 Trail guide... Does it work??
    By aappling72 in forum Ibis
    Last Post: 04-07-2012, 03:58 PM
